No Brake Fluid
Old Jul 7, 2013 | 06:51 AM
Troy Banning's Avatar
Troy Banning
No Brake Fluid
My brakes are feeling a little spongy, so I figured I would bleed them just to make sure there was no air. I had my son pump the brakes, but when I cracked open the RF bleeder nothing came out, same on the LF. I removed the RF bleeder completely, with no fluid coming out at all. HELP! This on a 2000 F-350
Old Jul 7, 2013 | 08:12 AM
mueckster's Avatar
mueckster
How about the rears? Have you checked them also? You should see some fluid flow from the caliper bleed port just with gravity.
Old Jul 7, 2013 | 10:13 AM
Troy Banning
I haven't checked the rear ones yet.
Old Jul 7, 2013 | 10:24 AM
JWC 3's Avatar
JWC 3
You have fluid in the master ?
Old Jul 7, 2013 | 10:32 AM
guitarpicr's Avatar
guitarpicr
Should start with the pass rear then drivers rear . Start with the brake farthest from the master cylinder. How many miles on truck - Have they ever been bled ?
Old Jul 7, 2013 | 04:34 PM
Troy Banning
Problem solved, bleeders were dirty. To answer some of the questions, yes the MC had fluid, and I actually take it to a place and have the fluids flushed, they charge $60.00, the truck has 125,000mi. on it. Thanks for the help.
F-250 restorer
23
Dec 12, 2010 12:16 PM
jsutton
May 6, 2008 10:15 PM
BiodieselPanther
1983 - 2012 Ranger & B-Series
Jan 13, 2006 09:12 PM
ccoram
1997 - 2003 F150
Mar 30, 2005 02:22 PM
bdclark
1978 - 1996 Big Bronco
Aug 12, 2003 10:11 PM
