Sponsored by: Real Truck
Bowing coil after leveling kit install
Old Jul 6, 2013 | 09:48 PM
clichtenfelt's Avatar
clichtenfelt
Hey everyone, new to the forum! I have a 2005 2wd F250, and today I began the install of a 2" aluminum leveling kit (the coil spacer variety). Everything was going smoothly until I tried to rebolt the coil spring to the upper bracket. because of the added height from the spacer, the coil has a bow, or "bulge" in it, attaching at the bottom and bending out toward the rotor. Does anyone know the remedy for this? Will it correct itself after a good alignment? or should I shim up the spacer? Please forgive my ignorance if this is common, a little bigger animal than my jeep that I lifted! Thoughts and opinions would be greatly appreciated!
Old Jul 6, 2013 | 10:39 PM
clichtenfelt
Old Jul 7, 2013 | 08:31 PM
clichtenfelt
bumping thread
Old Jul 7, 2013 | 09:49 PM
spook222's Avatar
spook222
My coils bulge like you are describing. I was concerned at first, but after double checking and making sure they were indexed correctly I just decided to run it. That was 140,000 miles ago and it seems fine. Kinda irritating to look at though
2011 f350
Old Jul 7, 2013 | 11:36 PM
clichtenfelt
Thanks for the reply! Have you noticed anything different about how your truck rides after you installed your leveling kit? Also, did you take a look at the picture I added, to see if your coils bowing to the degree that mines at right now? It just seems pretty out of whack, like it might blow out on an especially hard bump
Old Jul 8, 2013 | 09:01 PM
clichtenfelt
hate to keep bumping the thread, but I'd love to get this coil situation figured out, I don't want anyone driving it if safety will be compromised.
Old Jul 8, 2013 | 11:46 PM
spook222's Avatar
spook222
Your pics aren't showing up. I didn't notice at first it was 2 wheel drive. Mine is 4. Mine do have a pretty good bow to them. Mine wandered a bit as it changed my caster a bit so I had an alignment done. Probably could have gone without the alignment as it wasnt too bad but it needed one anyhow. Hope this helps
mikerans
Jun 2, 2012 01:54 PM
Dlasure2
Jun 25, 2011 10:25 AM
jlcote
Jul 7, 2009 12:38 PM
04heritage4.2
1997 - 2003 F150
Oct 4, 2005 11:26 AM
