hydroboost ??
Old Jul 4, 2013 | 07:12 PM
XLT89F350cc's Avatar
XLT89F350cc
hydroboost ??
on a gas motor, will there be enuff vacuum if brake booster is changed to a hydroboost ??
Old Jul 4, 2013 | 07:29 PM
blkF250HD's Avatar
blkF250HD
The amount of engine vacuum generated will remain the same if you switch to a hydroboost system.
rla2005's Avatar
rla2005
The engine is the vacuum source. Whether or not you have a vacuum or hydraulic style brake booster has no bearing on how vacuum the engine can supply.
Old Jul 4, 2013 | 07:30 PM
XLT89F350cc
so there will be enuff vacuum for heater controls ?
Old Jul 4, 2013 | 07:33 PM
blkF250HD's Avatar
blkF250HD
Yes. As previously mentioned, the engine creates the vacuum, not the brake booster. Is there a problem with your vacuum booster system that's causing you to switch to hydroboost?
Old Jul 4, 2013 | 07:35 PM
XLT89F350cc
just wanted to make sure, thx for the quick answers.
Just want bigger an better on dads dually
tassmannn
May 31, 2017 07:25 AM
monte97z
Apr 15, 2017 10:13 PM
ungerp
Jun 30, 2013 02:57 PM
77F150Jason
Oct 29, 2006 03:18 PM
hotbbb
Feb 2, 2004 02:37 PM
