Engine surging / erratic idle / studderring
Old Jul 4, 2013 | 10:34 AM
Glsimmons1's Avatar
Glsimmons1
My 2002 F250 7.3 is having some probs. when I start the truck, the engine surges from 1500 RPMs to about 500. If I push on the gas and keep RPMs constant for about 10 seconds, when I let go it will steady the RPMs but when I drive it is rough and studders and hard shifts till the engine gets to operating temps. I just changed out the glow plug relay and that improved the studderring but now I have the surging issue. Truck has 270,000 on it and I just got it so not too sure what all has been done
Old Jul 4, 2013 | 12:07 PM
snakedoc's Avatar
snakedoc
i would check the icp and the ipr, or the ipr nut.
how old is the oil is it full
Old Jul 4, 2013 | 12:29 PM
Glsimmons1's Avatar
Glsimmons1
Oil is fresh! 30% Lucas oil additive and 70% rotella..
Old Jul 4, 2013 | 12:49 PM
petrokiller's Avatar
petrokiller
Check the fuel filter or just go ahead and change it.
Why all the Lucas additive??
Did it just start this all of a sudden??
Old Jul 4, 2013 | 01:12 PM
Glsimmons1's Avatar
Glsimmons1
The erratic idle just started but the engine studderring has been going on for a bit. The Lucas oil was to he fully help with the studderring. Thought there might be some build up on a lifter or something internal that may be causing the studderring issue. How do I check icp or ipr? Nut seems tight on the ipr. Will change filter but it is less than 2000 miles old.
dluchsin
Apr 19, 2014 09:50 PM
Brant Bowrifle
Jul 11, 2012 03:57 PM
Justin Time
Jul 6, 2008 10:29 PM
Medic 66
20
Mar 2, 2006 08:19 PM
nosvmax
Mar 30, 2001 01:42 PM
