Sponsored by: Real Truck
Speedometer
Old Jul 3, 2013 | 03:47 PM
twotappan's Avatar
twotappan
Speedometer
Hello
I have a 2002 F350 v10. I have 101,000 miles on it. When the Speedometer hit 15mph it starts to climb Rapidly to a 100mph then it stops and goes to 0. My miles go blank and when I slow down to around 5mph it comes back. Any ideas? I do know that I have a bad clock-spring and am changing that this weekend.
Thanks
Traves.
Old Jul 3, 2013 | 07:01 PM
redford's Avatar
redford
FTE Leadership Emeritus
It is either the speedometer itself or the VSS sensor.
Old Jul 3, 2013 | 11:26 PM
BigOl04's Avatar
BigOl04
thats called some sick power to turn the wheels up that fast.. lol... deff sounds like the vss sensor like redford said
Old Jul 4, 2013 | 03:18 AM
Yahiko's Avatar
Yahiko
If you have access to a good scanner you should be able to
see if there are any codes. The Autozone scanner won't do it.
The AE or a Snap-On or one of that level will give you the info.
Sean
Old Jul 4, 2013 | 07:58 AM
twotappan's Avatar
twotappan
Sean
I have done a diagnostic test with a snap on tester. Codes that came up are. B1932, C1226 & P1000. Can't find out what they are..
Thanks
Traves Tappan & the "Beast"
Old Jul 4, 2013 | 03:16 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Anyone have a part number for the vss?
My speedo acts funky as well. Not sure if it's the input to inst. cluster or the actual speedo on cluster
Old Jul 4, 2013 | 03:17 PM
Yahiko's Avatar
Yahiko
The P1000 is a indication that the self testing cycle has not been finished. Battery power
was removed and that will cause it.
The B1932 in my book for the 06 year is "driver side airbag circuit open"
Bad clock spring you say? That may be the reason
The C1226 I cant' find but it should be a chassis circuit.
c1226 - Ford Truck Enthusiasts Forums - Threads Tagged with c1226
or this one
https://www.ford-trucks.com/forums/9...ine-codes.html
There is a very nice DTC list in this thread
https://www.ford-trucks.com/forums/4...self-test.html
This is what I found.
C1226 Lamp Brake Warning Output Short to Ground ABS
Be sure to pass on some reps to the person that posted the DTC list.
Sean
Old Jul 4, 2013 | 03:21 PM
Yahiko's Avatar
Yahiko
I just found a very nice online tool for DTC lookup.
OBD II Diagnostic Trouble Code (DTC) Definitions
Sean
Old Jul 4, 2013 | 03:27 PM
RBlac's Avatar
RBlac
i remember when my vss went out. One of the first times I ever looked to FTE. I was a bit scared, truck speedo was jumping, and truck was running like $###. I thought something major was up. Turned out a simple cheap fix.
Thanks again FTE!! Hope this is the case here. Although I do remember having driveability issues when mine went out as well.
Good luck!
Old Jul 6, 2013 | 10:23 AM
twotappan's Avatar
twotappan
Okay do I changed the sensor on the back of the rear end. That did not help. I have purched the VSS that mounts to the transmission. I think I have located it on the top of the transmission. Do I have to drop my trannismission to install this thing? Or am I looking at the wrong thing. I also hooked it up to a scanner and took the truck on a drive. The scanner was reading my speed so I am kinda ruling out the sensor at this point being bad. Could it be my cluster??
Old Jul 6, 2013 | 03:49 PM
Yahiko's Avatar
Yahiko
I would lean to the cluster myself at this point.
Sean
Old Nov 26, 2013 | 08:18 AM
twotappan's Avatar
twotappan
LinkBack Thread Tools Search this Thread Rate Thread
#1 (permalink) Add to twotappan's Reputation Report Post
Old 07-03-2013, 01:47 PM
twotappan twotappan is online now
Garage is empty, add now
twotappan is starting off with a positive reputation.
Speedometer
Hello
Thanks
Traves.
Reply With Quote Multi-Quote This Message Quick reply to this message
#2 (permalink) Add to redford's Reputation Report Post
Old 07-03-2013, 05:01 PM
redford's Avatar
redford redford is offline
2007 Ford F-250
redford has a brilliant futureredford has a brilliant futureredford has a brilliant futureredford has a brilliant futureredford has a brilliant futureredford has a brilliant futureredford has a brilliant futureredford has a brilliant futureredford has a brilliant futureredford has a brilliant futureredford has a brilliant future
__________________
2007 F-250 Super Cab Short Bed 4x4 XLT Sport Package 5.4L 3.73LS Tow Command
Stuart
Retired Master Sergeant
FTE Guidelines
#3 (permalink) Add to BigOl04's Reputation Report Post
Old 07-03-2013, 09:26 PM
BigOl04's Avatar
BigOl04 BigOl04 is offline
2004 Ford F-250
My Garage
BigOl04 is starting off with a positive reputation.
@brockeggleston
#4 (permalink) Add to Yahiko's Reputation Report Post
Old 07-04-2013, 01:18 AM
Yahiko's Avatar
Yahiko Yahiko is offline
Yahiko has much to be proud ofYahiko has much to be proud ofYahiko has much to be proud ofYahiko has much to be proud ofYahiko has much to be proud ofYahiko has much to be proud ofYahiko has much to be proud ofYahiko has much to be proud of
Sean
__________________
Three Happy Cats "How do you eat an elephant? One bite at a time!"
Mods Blue Spring, High Idle(BCP), Coolant Filter,SCT from Gearhead Automotive Performance
HFCM Drain Plug, Nav System, Leveling Kit, Backup Camera, HID Fog 3000K & Driving Lights 4300K
6.0l Forum Map : Ask me About It
#5 (permalink) Add to twotappan's Reputation Report Post
Old 07-04-2013, 05:58 AM
Sean
Thanks
#6 (permalink) Add to Tylus's Reputation Report Post
Old 07-04-2013, 01:16 PM
Tylus's Avatar
Tylus Tylus is offline
Nuke Mechanic
2002 Ford Excursion
Tylus has a brilliant futureTylus has a brilliant futureTylus has a brilliant futureTylus has a brilliant futureTylus has a brilliant futureTylus has a brilliant futureTylus has a brilliant futureTylus has a brilliant futureTylus has a brilliant futureTylus has a brilliant futureTylus has a brilliant future
__________________
United States Navy - MMC (SS)
2002 Excursion XLT w/ V-10 <-- The new toy build thread
2012 Flex Limited <-- El Wifey's Ride
#7 (permalink) Add to Yahiko's Reputation Report Post
Old 07-04-2013, 01:17 PM
Yahiko's Avatar
or this one
https://www.ford-trucks.com/forums/96...ine-codes.html
https://www.ford-trucks.com/forums/43...self-test.html
Sean
__________________
#8 (permalink) Add to Yahiko's Reputation Report Post
Old 07-04-2013, 01:21 PM
Yahiko's Avatar
Sean
__________________
#9 (permalink) Add to RBlac's Reputation Report Post
Old 07-04-2013, 01:27 PM
RBlac's Avatar
RBlac RBlac is offline
RBlac is starting off with a positive reputation.
Good luck!
__________________
1999 F250 SD 5.4, Auto, 4WD, SCLB
#10 (permalink) Add to twotappan's Reputation Report Post
Old 07-06-2013, 08:23 AM
Okay I changed the sensor on the back of the rear end. That did not help. I have changed the VSS that mounts to transmission. That did not help. I have changed out my clock spring. That did not help. I have had my cluster rebuilt. That did not help. I also hooked it up to a scanner ( Snap-On) and took the truck on a drive again. The scanner is reading my speed and is right on with my GPS that I use to tell me how fast I am driving. I just want help or any idea that it could be... I am very frustrated at this point.. Truck is running fine no misses or any other problems at this time..
Old Jun 1, 2021 | 05:23 PM
eduardomorocoima's Avatar
eduardomorocoima
Originally Posted by twotappan
Hello
Thanks
Traves.
mano yo tengo el mismo problema el camion llega a 80k/h y de alli no pasa
TPM
Apr 12, 2007 08:21 PM
