Replaced Multifuction Switch, now engine won't start. (Antitheft?)
Old Jul 2, 2013 | 05:40 PM
gobrinton's Avatar
gobrinton
1993 Ford E350, 460 ci.
I replaced the multifunction switch because one turn signal stopped working and the problem traced to the switch. I had to remove the ignition switch in order to remove the shroud. The new multi-switch is in, turn signal works, engine cranks but won't fire up. (It fired right up before the repair.)
I remember reading something that if you install a new ignition switch, it must be programmed for the vehicle. However, I didn't install a "new" ignition switch, I simply removed it and reinstalled the same one.
Am I screwed?
Old Jul 2, 2013 | 07:09 PM
gobrinton's Avatar
gobrinton
Oh wait! I think I may have found the problem.
I removed the steering column cover for a closer look and there was a wire hanging from the key lock assembly. It clips on near the top (opening) of the key lock outer cylinder. However, the plastic clip is broken and the contact won't stay in place.
Yup, I'm screwed.
Old Jul 3, 2013 | 04:25 PM
gobrinton's Avatar
gobrinton
I replaced the wire connector today with a new one. She still won't start. Now I am left puzzled again. I don't see anything else wrong in there.
The motor cranks but won't even try to fire off. No spits or sputters, which indicates that the problem is electrical.
Are there any circuits in the multifunction switch that would stop the engine from firing up?
Any ideas would be appreciated.
southern-old-bold
Jun 25, 2018 08:01 PM
Peanuts' crew
Jan 21, 2015 08:50 AM
imper
Computer Chips & Tuners
Aug 18, 2014 07:00 PM
bobbyb61b
Dec 27, 2010 06:31 PM
ligito
16
May 1, 2009 07:32 PM
