Sponsored by: Auxito
Shock absorber and frame problem
Old Jul 2, 2013 | 01:06 PM
Acameron19's Avatar
Acameron19
I have a 2002 f150 xlt 5.4l v8 and the part of the frame that the top of my shock goes through and bolts on cracked and bent upwards to the point which the top of the shock isn't even connected to my truck anymore. I need to know how to get the fixed and if it needs a pro or I can do it my self
Old Jul 5, 2013 | 06:58 PM
LxMan1's Avatar
LxMan1
I would let a frame/body shop look at it to make sure it isn't a safety issue. They can also guide you in the right direction for repairing the frame if it safe to do so.
Old Jul 6, 2013 | 11:39 AM
RebColonel's Avatar
RebColonel
My sons' '98 F-150 4WD had a shock do exactly the same thing as yours. The problem was caused by a Rancho shock they sold him that was the wrong length, it was too long in its collapsed position. In other words the shock shouldn't bottom out before the suspension does. The part that broke out can be rewelded in place. Make sure the shock is the right one for your truck and that you can collapse it by hand easily.
Old Aug 20, 2013 | 02:24 PM
Acameron19's Avatar
Acameron19
awesome thank you and one more question I bought this truck last year right before I left on deployment and cant figure out what size lift kit is on it how do I figure that out ?
Old Aug 20, 2013 | 10:18 PM
steve(ill)'s Avatar
steve(ill)
well what did they lift? Add blocks or just crank up the torsion bars ? Should be blocks on the rear axle you can measure... Lift kit / long shocks / broken frame... this is starting to add up.
Old Aug 21, 2013 | 04:53 PM
GuyGene's Avatar
GuyGene
Acam, man, I'd like to see a photo of that! Hope ye get'er fixed!
alaskawoobie
1997 - 2003 F150
May 7, 2013 03:35 PM
Pappys53
Sep 2, 2011 09:11 AM
sandhillmike
Aug 30, 2006 02:01 PM
Scrapiron66
Aug 22, 2006 01:57 PM
5.8L95f150
17
Sep 20, 2005 03:50 PM
