bad idle
Old Jun 11, 2003 | 01:32 AM
cpettymore7777's Avatar
cpettymore7777
bad idle
have a 1980 300 1bbl. when it is idling for 2 min ,warm or cold, it starts to studder. i look under the hood and i see gas coming from the bottem of the carb at the gasket . this engine has only 8,000 on it (jasper reman). also when you run it for awhile then turn it off for 5 min and try to start it, it is hard to start. the carb is only 2 years old. any ideas
Old Jun 11, 2003 | 11:37 AM
steve83's Avatar
steve83
bad idle
Sounds like either the needle valve isn't closing for whatever reason, or the accelerator pump diaphragm ("power valve") is ruptured. Either way, you need to rebuild it. When you buy the rebuild kit, read thru the instructions a couple of times and circle or highlight the sections that apply to your carb, and take notes of the gauge sizes you'll need to set everything. For the float setting, you usually use a specific drill bit as a gauge, so buy them before you start.
Old Jun 11, 2003 | 04:08 PM
cpettymore7777
bad idle
thanks i will try that. i have the old carb in the box. i may as well rebuilt it since it is just sitting there.
