AC questions
Old Jul 1, 2013 | 12:50 PM
Stinky1's Avatar
Stinky1
AC questions
I just popped an O-ring on my '84 Econoline w/dual AC, right at the dryer. I changed them all. On the rear AC lines, oil was pooling in the lines... A-LOT. If I lowered the line, oil would pour out. Is that an issue?
Also, the sticker says that it should take 4.25# of R12. What would be the correct amount of 134? I put in 3# and my gage shows full pressure. But, it is not cooling as well as it should.
Old Jul 2, 2013 | 09:19 PM
Club Wagon's Avatar
Club Wagon
Did you change all the O-rings to R134 compatible O-rings?
R12 vintage O-rings don't usually stand up to R134 refrigerant oil for very long.
Without knowing the service history of an AC system it's impossible to know just how much oil has been put in. Too much oil reduces effiency. It's also a sign previous work sought to help grumpy compressor. Running an R12 system on R134 also reduced efficiency.
For advice it would be better to state what actual PSI your "gage shows" instead of the nebulous "full pressure".
In order to be "cooling as well as it should" the high side should likely be ~300 PSI.
Old Jul 15, 2013 | 03:30 AM
Stinky1's Avatar
Stinky1
When the O ring popped, I changed them all.
I'm not sure that my gage has the PSI on it. It has a Blue (for low), Green, and then Red. My pressure was at the middle of the Green, in the afternoon, when it was hot out. The next day, I tried it in the am and it was at the bottom of the green. I added 1/2 a can and it works pretty good now.
Thanks for the input.
Old Jul 17, 2013 | 11:53 AM
BII Plow Truck's Avatar
BII Plow Truck
Charge R134a to 60% of what R12 capacity was. That's if you evacuated the system down to 28-30 hg in vacuum first for at least an hour. If you don't evacuate it to a vacuum, the air will throw everything off.
Old Jul 17, 2013 | 12:24 PM
Club Wagon's Avatar
Club Wagon
Those simple, low side, DIY charging gauges are OK on systems in good shape, but don't reveal a worn out compressor. You need high side pressure reading to see compressor function & guard against overcharging or blockages.
BII Plow Truck is right about vacuum deairing any system that's been opened up. It's not just air that "will throw everything off" but also the moisture in air.
IMO the best way to tell if "it works pretty good now" is to use an AC thermometer. A good AC system will pull down to ~40F.
Akzep69
1978 - 1996 Big Bronco
Jun 20, 2015 04:07 PM
BroncoPhilly
Jul 24, 2010 08:38 PM
fordman1090
17
May 7, 2008 05:56 AM
Merlin509
Jun 8, 2005 06:09 AM
javi2001
Aug 23, 2003 08:01 PM
