I have a 390 with new process 435 with 4.10's. No rpm gage, its screaming by 50 but ive ran it at 60 a couple times for about 10 miles. Do you guys like number dummy think that is ok and it wont hurt the motor? It doesnt overheat at all.
I've got pretty much the same configuration but with 3.50 rear gears (and 35s) and at 3,500 RPM it is screaming for mercy. Get yourself a Sun SuperTach II at Autozone for about $45 and it'll provide the information you need. I have my redline set at 4,000 RPM just cuz there's no need to go any higher than that.
If you have a 28" tire, you would be turning 2460 rpm at 50 MPH, about 20 mph per 1000 rpm.
If you have a 31" tire, you would be turning 2222 rpm at 50 MPH, about 23 mph per 1000 rpm.
Our '66 wagon with 390 2v and single exhaust sounded like it was going to come apart when shifting out of first at 40 mph. That was at approx. 3542 RPMS...... Wonder how they ever got one to 4400 rpms for the supposed peak power of 265 horse.....
I'd get a tachometer and see what the rpm's are, for what its worth my buddy had a 94 with a 460 no OD with 4.10s and was turning 5,500 rpm at 95 mph and he did that quit often.
Ok thanks a lot for the imput guys.. sounds like I have to get a tach, maybe this seems obviose, but where do I hook up the tach? Is it a pretty big deal to put one in?
4.10s, 95 MPH and 5500 RPM would require a 24 inch tire.....
IF the op can post his tire size, we will know the revs without a tach.
As for installing a tach, it's usually a hot, ground, the lights and the negative side of the coil or a sender that clamps on to a plug wire.
The tach will have instructions with it, or if you buy it at a yard sale, you can go to the manufacturer's web site and get instructions, if it is at all current.
I have 16 inch 265's, i measured them and they look like they are 32 inch. Thank you for the reply, let me know what you think about the revs with these size tires
Generally classic truck V8's can handle cruising at low 3000's RPM. My 400 does OK there. That should be 70-75 MPH with 4.10's and 32" tires. Yes its spinning faster than a modern OD unit but it should take it fine. Your original tires were probably smaller (29"?) so your spedo is off. Check speed wit.h a GPS to be sure and calculate RPM accordingly.
ok I'll do that but it sounds like I can go at least 70 without damaging anything, thank you for the reply
It didn't have 24" tires LoL but with 265/75-16 and a C6 and we thought 4.10s (that's what the diff tags said and didn't look like they had ever been opened) when it hit the speed limiter 94-95 mph the stock tack was over 5k and it seemed to be accurate.
My brother-in-law has a 72 Chevy with 4.10s and turns the same rpm's with the same tires? I would just get a tack and know what its doing.
