F250 Transfer Case Problem
Old Jun 30, 2013 | 07:31 PM
OldGrayFord's Avatar
OldGrayFord
Hey Guys, I'm dealing with a transfer case problem I'm hoping someone may have some ideas on where to start. 89 F250 7.5 5speed. Manual hubs, manual transfer case shifter. So last night I put my truck in 4 low to tow my ski boat up my long gravel driveway. I noticed the transfer case shifter seemed to be moving back and forth a little bit. I heard a kind of popping sound when I first started moving, like something was in a bind but it only did it once. So this morning I went to use the truck and I could immediately tell its stuck in low range. I took it out of 4wd last night, but hadn't gone anywhere. So far I've confirmed the linkage is moving the lever arm on the transfer case. I can also confirm that it is in low range regardless of the ****er position 2H,4H,N or 4L.
Any tips on where to begin would be appreciated. I'll probably be pulling it later this week. Hopefully it's something that can be fixed rather than needing to replace it. Thanks
Old Jun 30, 2013 | 08:38 PM
jasoncarpenter1's Avatar
jasoncarpenter1
Its the plastic guide on the shift fork. Mine went bad because i was low on fluid, had a leak. The pic's are ****ty cell phone but you can see its pretty easy............
Old Jun 30, 2013 | 08:50 PM
OldGrayFord
Thanks for the pictures. What parts did you have to replace? Any suggestions on parts supplier? I appreciate the response
Old Jun 30, 2013 | 11:13 PM
jasoncarpenter1
I had a donor trans case laying around. I'm sure someone has a rebuild kit.........
Old Jun 30, 2013 | 11:25 PM
OldGrayFord
Ok thanks for the help.
Koolkat
WTB - Parts & other
Apr 17, 2017 07:16 PM
frank washington
Mar 9, 2017 01:53 PM
Spankymeyer
May 5, 2016 03:03 AM
84 f250 6.9
Aug 23, 2009 12:18 PM
Nick_F150
Dec 22, 2008 03:53 PM
