Sponsored by: Real Truck
key on power
Old Jun 30, 2013 | 04:52 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
key on power
I am adding a fuse box to my truck under the dash where is there a good sized key on wire that I can tap into? I think before the main fuse box is best so I don't blow any fuses for other stuff but large enough yo handle a load. I don't know how much of a load I will be running through the box but I'd like to have it wired properly in case I run a compressor or lights through it.
Old Jul 1, 2013 | 10:27 AM
Firekite's Avatar
Firekite
The proper way to do that is run power directly from the battery to a relay that is switched on by tapping into an ignition-powered 12v accessory wire. You do NOT want to try to power a fuse block for high-load items like lights and compressors based off of some accessory wire. It'll either not work (i.e. blow a fuse immediately, every time) or burn your truck to the ground. Either way, it's not really desirable...
Old Jul 1, 2013 | 12:07 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Thats what I ended up doing
Sku11ey
Nov 30, 2018 11:01 PM
Firekite
Sep 1, 2017 11:07 AM
gnwalker
Electrical Systems/Wiring
Jan 28, 2014 11:49 AM
learpilot
Sep 23, 2009 05:00 PM
jason86
1997 - 2003 F150
Oct 12, 2004 01:16 PM
