Looking for Highboy Frame Perches
Old Jun 30, 2013 | 02:42 PM
bigfootsurfin's Avatar
bigfootsurfin
Howdy all. I tried posting this in the classified section, but got no hits. I figured this would be the place since there are plenty of Highboy owners on here.
I have a restored '66 body on a powdercoated '71 highboy chassis. Finally decided on an engine. Problem is, I lost the factory engine mount frame perches in a move. I recently decided to install a 1996 300 I6 and zf5 from an f150 and was wondering if anyone has any extra highboy perches to mount a 300 six? I know they are the same as FE ones, but does the 300 installed on FE mounts have different mounting brackets on the engine side, or do the insulators mount directly to the engine and the perches just get installed in the far forward position? I'll need everything to mount this engine my truck because currently I have nothing at all.
Information or parts would be appreciated...
Thanks, Sam
Old Jun 30, 2013 | 06:46 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
F100/250 240/300 w/4WD not the same as F100/250 FE w/4WD.
4WD's do not have perches, as there's no engine cross member to bolt them to like there is on 2WD's. 4WD engine brackets (supports) bolt to inner frame rails.
D6TZ-6028-A (replaced C6TZ-6028-C) Right & D6TZ-6029-A (replaced C6TZ-6029-E) Left .. 4WD Front Engine Mount Brackets / Obsolete
1966 F100 240/300 / 1967/74 F100/250 240/300 / 1975/76 F100/250 300 / 1977 F250 300 before serial number Y20,001 / 1977/79 F150 300.
Old Jul 1, 2013 | 12:16 AM
orich's Avatar
orich
Gees I beed trying to sell a pair in the classified section for a few mouths. Had them painted with black PRO 15 with bolts.. No takers so dumped them a long with my 24 tc at pick n pull return core box with some 13" U-bolts All good stuff. I don't have any more storage othe then the back of my truck. ... Oh well to late now...orich
Old Jul 1, 2013 | 02:58 AM
RichS2659's Avatar
RichS2659
Doesn't the 240/300 use the same engine supports as the 360? The parts diagram dated Jan 75 shows no mention of having two different engine supports between the Six and the V-8, only the engine isolators.
Old Jul 1, 2013 | 08:12 AM
orich's Avatar
orich
Yea my truck had a 300 I-6 when, I got it. only move them forward or backwards can't remember which way as did the swap to a 390 1978. orich
Old Jul 1, 2013 | 12:38 PM
NumberDummy
4WD uses different brackets than 2WD
You cannot go by parts catalog diagrams (illustrations) as all you're seeing is basic part numbers which are the same 2WD/4WD.
The text section is required to get the full part number, by adding the prefix and suffix to the basic part number.
Upper pics: Here's the info from the 1964/72 text catalog. The 240/300 4WD part numbers were replaced in 1976 (see post 2).
Left upper: 240/300 / Right upper: 352/360 (390).
Left/Right lower 4WD & 2WD: 240/300/352/360(390) = same basic part numbers.
Old Jul 1, 2013 | 01:15 PM
crazed87bronco's Avatar
crazed87bronco
I have a set of engine brackets came off my 71 f250 crew cab 4x4 had a 360 in it.
Old Nov 23, 2013 | 08:18 PM
chevys-suck's Avatar
chevys-suck
Still confused are the engine supports for the 300 the same as the for the 360 or not? and vise versa. I have a 1974 f250 4x4 looking to swap in a 300 and pulled out a 360.
Old Nov 23, 2013 | 08:29 PM
garbz2's Avatar
garbz2
Move the engine mounts to the front set of holes for use with the 300.
Garbz
Old Nov 23, 2013 | 08:31 PM
garbz2's Avatar
garbz2
Double Post
Garbz
Old Nov 23, 2013 | 08:36 PM
chevys-suck
Thanks bud! I tried doing that this morning and it seems the front vertical holes inside frame have nowhere to go. Did not try yet but is it possible that I need to swap from side to side?
Thanks
Old Nov 23, 2013 | 08:39 PM
orich's Avatar
orich
Look at the frame and you'll see extra set of holes about 2" or so forward of the 360 frame holes. You'll also need clutch linkage & a different bell housing exh. pipe, shock mounts may have to be moved forward too. orich
Old Nov 23, 2013 | 09:01 PM
chevys-suck
I've got all the other mentioned stuff figured out I already had it set up for a 351c with the zf5 so the clutch master and slave is done but for some reason when mounts are moved forward the front two holes are covered up by the mount that's why I was wondering if they needed to be swapped from side to side
Btw the only reason I made mention of the 360 is because that is what I pulled when installed 351c.
Old Nov 23, 2013 | 09:51 PM
orich's Avatar
orich
The mounts will notswitch left to right change sides per the way their designed. One side is a little longer arch then the other side is.
I don't think you had the bolts lined up to go through the other side frame holes..orich
Old Nov 27, 2013 | 12:44 AM
chevys-suck
Well, I moved the mounts forward and that worked. Had to slot the front holes to get them to bolt on the front set of holes on both brackets. I ordered new engine mounts/ insulators. but had to order them from a 75 highboy cause the o-reiley website did not show the 74 with the 300ci. only the 240ci. Hopefully they are the same if not I will order them for the 240ci. and hope they fit.
