Pulled light switch and checked rheostat and spring.
Did you check the spring on rheostat to make sure it was connected. My was hard to see but broke on one end. Solder it back on and still works good, switch was less than a year old.
Yes I did. I even went as far as to buy a new one from parts store since it was only a $20 part. Symptoms stayed the same with both switches.
I think the issue is in the plug between the wiring harness and dash. Not sure if I should spray some wd40 and see if that cleans it some or attempt to find a new plug and replice it in.
[QUOTE=CBSCW74;13313109]I think the issue is in the plug between the wiring harness and dash. Not sure if I should spray some wd40 and see if that cleans it some or attempt to find a new plug and replice it in.[/QUOTE
WD 40 won't hurt it, used on car stereo equipment all the time when I work at a shop. Cheap replacement for electronic cleaner
Could be the plug. No idea of where to get a replacement.
I might have a plug you can have. Had electrical problems about a year ago and replaced old harness. (Not a light problem ) If your interested let me know and I can check Sunday to see if I still have it. 70 f-100 harness.
If you still have it I would welcome trying a new plug - thanks.
I found 2 female connectors still connected to the harness. Not sure of the year but should work. Don't have the male connector. If your interested let me know and I can check with a meter to see if there good.
I would be glad to send you the switch but I did find one at advance that is new. Might be quicker and you would have a new piece verse one 40 years old. Let me know don't care either way, can send it to you if you want it.
