Using a compass to find a short?
Old Jun 29, 2013 | 08:03 AM
1'stonraceday's Avatar
1'stonraceday
The mechanics at work said that a regular old Boy Scout type compass will help locate a short in wiring. Any confirmation of this? Or are they just getting a chuckle?
Says it spins at or near the short because of the field created by current going to ground.
Old Jun 29, 2013 | 03:44 PM
Franklin2's Avatar
Franklin2
I can't say whether it would indicate anything or not, but I do know most wires in a automotive application are bundled together, and I would think it would not indicate anything with a bunch of other circuits bundled next to it. If you have to go over the harness close enough or tear it apart enough for this idea to work, you would find the problem visually long before you got to use your "indicator". I think they are pulling your leg.
Old Jun 30, 2013 | 06:18 AM
projectSHO89's Avatar
projectSHO89
A compass, by itself, will not work. You need to also inject an AC signal into the shorted circuit.
It's a heck of a lot easier to just buy a short circuit detector and use it.
Amazon.com: SG Tool Aid 25100 Short Tester: Automotive Amazon.com: SG Tool Aid 25100 Short Tester: Automotive
Old Jul 4, 2013 | 04:41 PM
fmc400's Avatar
fmc400
MSEE
All currents, DC or AC, are capable of producing a magnetic field (to which a compass is sensitive). Think "right hand rule." AC current comes up when you're talking about inducing a voltage, e.g. Faraday's Law.
As all have said, you cannot use a compass to find a short in a wiring harness. Even if the needle did move because of the field created by excess current to ground, I don't understand how you would correlate needle alignment to the physical location of the current flow in a bundled harness. And even then, current flows through the entire length of the wire between the source and the short to ground, not just at the physical fault.
77 ford shortbed
Nov 16, 2008 06:08 PM
77 ford shortbed
Oct 13, 2008 09:17 PM
ctubutis
Jun 29, 2008 09:22 AM
mlb4966
15
Aug 18, 2005 02:04 PM
mlb4966
Electrical Systems/Wiring
Mar 10, 2005 07:30 PM
