6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Stableloads
Old Jun 26, 2013 | 08:48 PM
senix's Avatar
senix
Stableloads
Got a set of these to test.
they work by engaging the overload before you put a load on go.
Should be an interesting piece of hardware
Here is a link to the website:
StableLoad - Lowest Cost, Most Effective Suspension Upgrade Available
Old Jun 26, 2013 | 10:24 PM
GHeTTo JOe's Avatar
GHeTTo JOe
so thats the no drill setup correct? was it as easy as they said it was to install on truck U. i am very intrigued with how well it will work and cant wait to hear your results. it looks so simple you wouldn't think it could make much difference. hurry back with some results!
Old Jun 26, 2013 | 10:37 PM
RM2738's Avatar
RM2738
I clicked on Ford 05-11 and it directed me to the A7311 Kit W/Drill setup. So I guess we do have to drill.
Old Jun 26, 2013 | 10:46 PM
GHeTTo JOe's Avatar
GHeTTo JOe
i looked again i think you found the E250 / E350 Vans. looks like 08-13 F250 Truck
Factory bed
A7310. same for the F350 Truck Factory bed except they also have the Stableload upper overload also
Old Jun 26, 2013 | 11:07 PM
RM2738's Avatar
RM2738
You are correct sir. Oversight on my part.
Old Jun 27, 2013 | 04:58 AM
senix's Avatar
senix
Yeah in this case it was no drill. Directions they came up with sucked but the picture was good.
Plus I have see other pictures.
In the F150 they help a lot with heavy loads. I will put some weight on it tonight and we will see.
Old Jun 27, 2013 | 08:06 AM
GSchretter's Avatar
GSchretter
COOL, thanks!!!..
Old Jun 27, 2013 | 09:06 AM
RM2738's Avatar
RM2738
Their website doesn't advertise cost? How much are they?
Old Jun 27, 2013 | 09:34 AM
senix's Avatar
senix
Not sure of cost for these yet. They are pretty new out there hence the testing of them.
Old Jun 27, 2013 | 10:20 PM
GHeTTo JOe's Avatar
GHeTTo JOe
senix you have totally stock suspension now right, other than the stabeloads? have you used air bags or any other of suspension helpers before?
Old Jun 28, 2013 | 05:06 AM
senix's Avatar
senix
I have the airbags, been using them since 2010. Thought I would try them anyway.
I am thinking even with the airbags it will stiff the suspension up some. Going down the road with the 5er you still get a certain amount of bounce if that sounds right. Especially over bridges and stuff. The airbags are bringing the load level and with these then It will engage the overloads full time and keep the bounce down I think.
Old Jun 28, 2013 | 08:50 PM
senix's Avatar
senix
Well I have been using the stableloads engaged and the airbags at 5psi. The suspension is a lot stiffer now both loaded and unloaded.
Ride height is basically unaffected but the bounce is gone.
Downside is you have to engage before you load up. So plan accordingly.
At this point I am recommending these as a low cost do it yourself way of enhancing your ability for those heavy loads.
Old Jun 29, 2013 | 04:37 PM
GHeTTo JOe's Avatar
GHeTTo JOe
is that what you normally would run the bags at? so unloaded its rough riding and loaded is smooth?
Old Jun 29, 2013 | 04:43 PM
senix's Avatar
senix
I normally leave 5 psi in the bags so as not to pinch them.
Not sure I understand the rest of your question.
Unloaded with 5 psi in the bags the ride is fine. Loaded down the ride is fine as well with the bags. You will still get a certain amount of bounce.
With the stableloads and bags the extra bounce goes away.
Old Jun 29, 2013 | 05:58 PM
preppypyro's Avatar
preppypyro
How low cost, is low cost?
