Ignition switch and plug
Old Jun 10, 2003 | 07:31 PM
derek_seli's Avatar
derek_seli
javascript:smilie('')
mad
I have a 76 f100 and there is a solid pink wire leading to the plug but was snipped just before the plug. What is this for and why would it be snipped off? Does anyone have a diagram labeling which wire does what?
Old Jun 10, 2003 | 07:38 PM
derek_seli's Avatar
derek_seli
There is also a red wire wrapped around a red wire with a green stripe(obviously not how it should be)? Does anyone know what this red and green wiredoes?
Old Jun 10, 2003 | 07:44 PM
Franklin2's Avatar
Franklin2
I don't have the diagrams, so I am going off memory (not good) but, those wire colors sound like the power feed to the ignition coil. I seem to remember the pink comes out of the switch, goes through the special resistor, and then goes to the red/green which goes to the positive of the coil. Check and see if I'm right by looking at the coil positive and see if it has the red/green. Sounds like maybe the resistor burned out and somebody may have bypassed it, or somebody at one time may have put in a high performance ignition that needed the resistor out of the circuit. If you have a stock ignition, you need the resistor.
Old Jun 10, 2003 | 09:58 PM
derek_seli's Avatar
derek_seli
sorry I was just looking at it in the dark. I guess the pink wire is actually purple(low brake light)
curtis73
Electrical Systems/Wiring
Dec 4, 2011 08:08 PM
internetgardener
Apr 3, 2009 11:12 AM
Mark W. Ingalls
Oct 3, 2008 09:17 AM
ZombieSlayer
Jul 17, 2003 01:26 AM
Endo51
Jun 30, 2003 01:53 AM
