390 ignition changeover
Old Jun 10, 2003 | 07:12 PM
coacholy's Avatar
coacholy
What cap, cap adapter, and rotor do I need to change my 1970 390 distributor over to the new style cap? I seen at Car Quest that there is about 3 or 4 different cap adapters that they list for different years. I plan on putting the pertronix kit in at the same time. What timing specs should I run with this(initial and total advance). What should I gap the plugs with pertronix kit installed? Any information would be greatly appreciated.
Old Jun 11, 2003 | 03:36 PM
chissler's Avatar
chissler
Carquest sells Standard brand ignition parts, part no.'s:
cap: FD168
adaptor: FD156
rotor: FD117
you might be able to advance it a hair
plug gap: .040"
don't forget you'll need new wires to p/n 6823 should work fine.
This conversion works better if you bypass the resistor wire and give it 12volts. Enjoy
351Cleveland C4
Jun 20, 2013 06:40 PM
sunnyb
20
Jul 7, 2010 01:05 PM
desoto dave
May 7, 2009 11:58 AM
Norm Spaulding
15
Mar 10, 2008 07:23 PM
360 Sport Custom
28
Nov 4, 2006 11:11 AM
