as Im driving everything goes dead radio, windows, dash, alarms, everything then turns on a usually 30 seconds later. is it a ground? is it a sensor thats getting to warm? is it a loose wire? where should I start??
Does the engine remain running? What about your lights? Is this dead dash syndrome associated with any event, like hitting a bump, turning left or running over a Prius?
i noticed the dash would come back on when I would hit a bump. the engine would stay running tho. as far as lights im not sure as I only drove durning the day so far
the gauges, radio, alarms (dinging for no seatbelt), and power widows go out. the lights work, the vent works, the lights work, and so does the cruise.
could that 30amp circuit breaker be going out in slot 601 on the fuse panel?
