Adjusting My Temp Guage
Old Jul 10, 2013 | 01:14 PM
Jag Red 54's Avatar
Jag Red 54
Alright, I am making progress. Everything that you guys are saying is right except for the actual temp at the thermostat housing. It is actually right on at 178* with the engine fully warmed up.
By adding resisters to the circuit, the gauge actually reads higher. I have bought a potentiometer rated from 0-25 ohms. My next step is to install it between ground and the connection point and adjust for accuracy. Right straight up the middle would be great. Thanks for sharing, Jag
Old Jul 11, 2013 | 11:56 AM
Jag Red 54's Avatar
Jag Red 54
Success! With the original gauge wire connected on the sensor, I ran the supplimental line to the sensor connection point. At 80 ohms of resistance between the sensor and direct ground the gauge reads straight up in the middle. Thanks for the help everyone. Jag (L)
Old Jul 11, 2013 | 12:03 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Does it behave normally at lower and higher temps?
Old Jul 11, 2013 | 12:26 PM
Jag Red 54's Avatar
Jag Red 54
I don't know about the cold and medium range because once that Y-block got up to temp I would have been out there to midnight waiting for it to cool off. I'll try it again tonight and watch the gauge as the engine warms up. Jag
Old Jul 11, 2013 | 02:34 PM
jboren's Avatar
jboren
My biggest concern would be to make sure it reads correctly when the engine overheats. It may never get over to hot now. Disconnect the sensor on the block, turn on the key and make sure the meter will stay at Hot. That still is not a positive indication that it will work at the high end as I don't know what the duty cycle of the sensor is at overheat temps. I suppose you could purposely block the airflow and monitor the temp and see what the gauge reads when the water temp is around 200* to make sure it is still accurate on the upper end (which is where I fear you may have problems with it not reading high enough) It will read cold now with no problem.
ATSDRIVER
Aug 23, 2005 05:32 PM
KeninCali
Sep 28, 2004 04:16 PM
hbronco
Feb 15, 2004 12:37 AM
ghambley
1997 - 2003 F150
Apr 9, 2002 08:12 PM
DrkPhanstm
Mar 4, 2002 08:46 PM
