6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
LV vs. SP again...
Old Jun 25, 2013 | 06:41 AM
Fert's Avatar
Fert
LV vs. SP again...
ok buddy of mine brought my attention to a post on a different site about some new service memo from Ford now saying that LV is not good for SP replacement except torq-shift..... Maybe.
i dont know if we can post the link or not.. i am if we not suppose to sorry...
http://www.powerstroke.org/forum/general-6-0l-discussion/458210-new-info-mercon-sp-vs-lv.html
i know it is for the 6.0 forum but has ties to 2008 trucks if you read enough.
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o>Fert</o>
Old Jun 28, 2013 | 09:34 PM
JUGERNAUT's Avatar
JUGERNAUT
here is the last ssm
SSM 21114 - REPLACEMENT TRANSMISSION FLUID FOR SERVICING TORQSHIFT TRANSMISSIONS
ALL 2003-2008 F-SUPER DUTY, 2003-2005 EXCURSION, 2004-2008 E-SERIES AND 2006-2008 LCF VEHICLES EQUIPPED WITH A TORQSHIFT AUTOMATIC TRANSMISSIONS SHOULD BE SERVICED WITH MERCON LV AUTOMATIC TRANSMISSION FLUID IN PLACE OF MERCON SP. THIS INCLUDES TOP OFF AS WELL AS FLUID REPLACEMENT. MIXING MERCON LV AND MERCON SP IN THE TORQSHIFT TRANSMISSION IS ACCEPTABLE. USE MERCON LV TRANSMISSION FLUIDTO SERVICE VEHICLES EQUIPPED WITH TORQSHIFT TRANSMISSIONS. WHEN ADDING OR REPLACING TRANSMISSION FLUID IN A VEHICLE EQUIPPED WITH A TORQSHIFT TRANSMISSION, USE MERCON LV TRANSMISSION FLUID. <!-- / message --><!-- sig -->
<!--?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o>Fert</o>
Ohh my god not this again! LV is the replacement for SP but you can use either.
and here is the chart
<!-- / message --><!-- sig -->ok your buddy needs to be informed here are the facts
Old Jun 29, 2013 | 08:10 AM
slowmans's Avatar
slowmans
They dont even make SP anymore, you dont have a choice unless someone has old stock.
Old Jun 29, 2013 | 09:29 PM
Tom's Avatar
Tom
I saw that thread on the other forum, and last time I checked there was no actual source that was posted. And the OP's description suggested that it only was harmful to 6-speed automatics, which were never put behind the 6.4L engine.
Old Jun 29, 2013 | 11:18 PM
JUGERNAUT's Avatar
JUGERNAUT
Exactly! Could not have said it better my self but the new 6 speed uses XT-10-QLVC and that is Mercon LV period
ccerniglia
Oil & Lubrication
18
Oct 17, 2008 10:51 PM
calf roper
Aug 29, 2007 02:54 AM
84-250
Oil & Lubrication
May 1, 2006 06:53 AM
90blue5.0
Escape & Escape Hybrid
Dec 1, 2005 09:17 AM
