1978 - 1996 Big Bronco
ABS Question
Old Jun 24, 2013 | 09:39 PM
MadMatt65's Avatar
MadMatt65
ABS Question
I ordered replacement rotors for the 93 Bronco. I'm kinda thinking I might as well go ahead and do all the bearings, seals and races. The 93 has 107K on it and the front bearings seem pretty tight. I found a hub/rotor combo from NAPA that has the ABS toner ring already installed. I've already got the replacement rotors only (stock style), but was thinking on getting some Powerstop slotted/drilled rotors instead. I see you have to remove the toner ring to press out the studs. Is that toner ring removable?? Press off and on?? Never done them before!
Edgethis
Sep 22, 2011 02:53 PM
Dmax Stroked 00
Apr 10, 2009 10:09 AM
djhoosier
Jul 14, 2006 10:23 AM
RA81222
May 25, 2006 07:16 AM
ed2hess
Nov 25, 2005 10:26 AM
