Bad Harmonic Damper?
Old Jun 24, 2013 | 06:04 PM
jb_man's Avatar
jb_man
I have a quick question for you guys.
I have an '83 F250 4x4 with a 460. It looks like the harmonic damper is going/is already bad. The outer ring is pushed in a bit, and the ends up the rubber material are sticking out of the front, and I can see some wobble.
How critical is it that I replace this? Can I drive the truck, or do I need to park it until I fix this. I intend to fix it either way, but is it a right now thing, or can I wait maybe 3 weeks?
Also, I've heard it called the harmonic damper, harmonic balancer, etc. What is the most correct term?
Thanks!
Old Jun 24, 2013 | 07:58 PM
Franklin2's Avatar
Franklin2
I have heard it called all the ones you listed. If you are doing a search, you may find different stores call it different things. It seems the word "harmonic" is a common term for most to use though.
If you need to drive it, ok, but go easy on it. No quick revs, try to be gentle with the rpms, because it can fly off the center piece. Once you get the new one on, I owuld re-check your timing, since the marks are on the outer ring of the balancer, and it could have slipped the last time the timing was adjusted. Just make a note of where the timing is with the new balancer before moving it. Stranger things have happened, and you might like the timing better where it is now.
Old Jun 24, 2013 | 10:44 PM
Rovernut's Avatar
Rovernut
I need to replace mine also ('85 460). Is there a higher quality or better value one than this?
Dorman 594-080 Harmonic Balancer : Amazon.com : Automotive Dorman 594-080 Harmonic Balancer : Amazon.com : Automotive
Dorman also makes one that sells for about $200, a racing version or something. I don't think I'll be racing my F-250.
Old Jun 25, 2013 | 06:10 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
OEM may be better quality but $60 seems a good deal Tom.
Old Jun 25, 2013 | 06:57 AM
Franklin2's Avatar
Franklin2
Here are the nice aftermarket ones, but they are expensive.
The Original Fluidampr
Old Jun 25, 2013 | 07:06 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Dave,
I only see one for internal balanced applications.
That would be pre-'79 for the 460.
Am I missing something?
Old Jun 25, 2013 | 08:14 AM
Rovernut's Avatar
Rovernut
Well, right now money is the primary concern, unless it's total crap.
Old Jun 25, 2013 | 08:25 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Tom, Dorman may source its product from 'over there' -but from what I see- their quality control is pretty good.
You're not revving your truck to 8,500 rpm.
If money and availability are are your issues I would go with it.
Old Jun 25, 2013 | 10:07 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
At the factory, a rubber gasket is placed between the inner damper and outer pulley, then the three parts are pressed together forming a one piece assembly.
Over time, the gasket age cracks/shrinks, causing the outer pulley to "walk away" from the inner damper.
If not noticed, pulley will fly off, taking assorted belts and etc along with it, may end up in the radiator core. Not pleasant!
D9TZ-6316-C .. 460 Crankshaft Damper (Harmonic Balancer) Assy / Obsolete
1979 F150/350 & Econoline (Use with block casting number D9TE-6015-AB only) / 1980/95 F250/350 & Econoline.
Old Jun 25, 2013 | 11:09 AM
jb_man's Avatar
jb_man
Well, I know what I'm doing this weekend. The price is definitely right on that one from Amazon... I'll give it a shot.
Thanks!
Old Jun 25, 2013 | 11:23 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Amazon shows 1 left...
The Dorman 594-080 is available on Ebay as well.
http://www.ebay.com/itm/DORMAN-594-080-Harmonic-Balancer-/261041431977?pt=Motors_Car_Truck_Parts_Accessories&hash=item3cc74825a9&vxp=mtr
OEM looks to be $72.53 + 7.99 shipping.
http://www.ebay.com/itm/D9TZ6316C-Pulley-With-Vibration-Damper-86-87-88-Bronco-/261082600247?pt=Motors_Car_Truck_Parts_Accessories&hash=item3cc9bc5337&vxp=mtr
Old Jun 25, 2013 | 11:29 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Rockauto shows 594-080 for under $50, but i don't know how fast or how much shipping.
http://www.rockauto.com/dbphp/x,carc..._Balancer.html
Old Jun 25, 2013 | 11:34 AM
NumberDummy
D9TZ-6316-C = Obsolete / Last MSRP: $88.74 / Dealer net cost: $59.16.
ebay seller clueless, no Bronco came w/a 460 = NONE!
Old Jun 25, 2013 | 01:10 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
It's an Ebay listing Bill...
Often a seller will make multiple listings of the same item with related keywords to get more exposure.
I'd imagine if the P/N is right, it is the right item.
They have the same item listed without any reference to a Bronco.
Probably just some keyboard monkey working from a printed list of available stock.
http://www.ebay.com/itm/D9TZ6316C-Ford-Pulley-With-Vibration-Damper-/261082600195?pt=Motors_Car_Truck_Parts_Accessories&hash=item3cc9bc5303&vxp=mtr
Old Jun 25, 2013 | 01:11 PM
Rovernut's Avatar
Rovernut
1993 FORD E-350 7.5L V8 Engine : Harmonic Balancer Auto Parts
Well, I refuse to do business with RockAuto and in any case shipping with them makes it as much as Amazon.
Alternatively, Advance Auto will price match RockAuto.
