One of the most common problems with IBC Controllers
AH! new information...
I've noticed that there are substantially more problems with the systems that have a secondary in-bed plug...
personally I always just run the pigtail over the tailgate, and I've never had a single false problem. If it says "TBC fault" or "trailer disconnected"... it's correct.
Steve
Each time I have had a problem with the brakes, I have tried the bumper plug, with the same results as with the bed plug. But, this has all been after the bed plug was added.
At one time, the problem was in the underframe connector and the lock clip was broken when the plug was pulled apart--this hasn't helped the long-term dependability of the system. Still, doesn't change the fact that Ford has placed a non-waterproof connection in a very vulnerable place. However, there are lots of Superdutys pulling trailers NOT having this problem, so guess the plug works most of the time.
I would not want the harness hanging over the tailgate just because of the rubbing it would do on the finish.
Steve, have you had any experience with the EZ-Connector plugs? Have seen the videos and online ads, but not heard of anyone using one yet.
Joe
Joe
Never had any problems with that connector on any of the other trucks.
Joe
Joe
Steve
The good thing about hanging the pigtail over the tailgate (if done correctly) is that it has exactly zero motion. The only thing it touches is the plastic cap on the tailgate. You have to run the pigtail all the way to the hitch, then back from the hitch to the plug below the bumper. This fixes the length of the wire run. If you don't go all the way to the hitch, the needed wire length changes around turns, and that's where you get motion from.
if you're good, you can slip it through the crack at the bottom.
Steve
Skydivelout
06-28-2017 09:57 AM
theologian
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
01-16-2004 12:42 PM
