Dont no what to do just broken my ecu who sells new ones
Old 06-23-2013, 11:35 AM
fordf350camper's Avatar
fordf350camper
fordf350camper is offline
Hello i have just tryed to remove i think its a ecu part number EECIV EF1-SD20B 33K EPROM E9TF-12A650-AS52A A9J and i have snapped a pin a connector i have looked to see if it can be soldered back but its not possible so my questions are which of the numbers are important who will sell one and whats it for.Is it for the gearbox if i could find out what that pin was for maybe i could just do away with it.I have looked on rock auto and i think they sell them.Its for a E150 1989 I think it snapped when i tryed to remove the plug at the back when i pulled it.Quite mad with myself.I think the numbers that are important are the E9TF-12A650-AS52A but whats the other numbers for A9J thank you
Old 06-24-2013, 09:49 AM
fordf350camper
Any idea there must be someone who sells them
Old 06-24-2013, 02:16 PM
blageurt's Avatar
blageurt
blageurt is offline
Old 06-24-2013, 02:32 PM
fordf350camper
Hi thank you just tryed that site and its saying no stock anyone else.I have been quoted £300 uk pounds over here.Not sure if thats about the correct price.
Old 06-24-2013, 02:36 PM
fordf350camper
Just sent them a message
Old 06-24-2013, 06:17 PM
blageurt's Avatar
blageurt
blageurt is offline
Old 06-24-2013, 06:47 PM
tabijan's Avatar
tabijan
tabijan is offline
There's this unit on eBay, assuming your van has a C6, but I don't know how to confirm that it's functional and appropriate for your van:
87 88 89 Bronco F150 Pickup Engine Computer ECM ECU PCM E8TF12A650BT2A | eBay
Then there's the caveat, "Control module may require programming before interchanging," but I doubt a module of this vintage could be flashed even at the dealership.
Sixto
93 E150 Chateau 5.8 185K miles
Old 06-24-2013, 08:09 PM
fordf350camper
That the wrong number but is there a stand alone ecu
Old 06-26-2013, 11:25 AM
gman97005's Avatar
gman97005
gman97005 is offline
There is nothing on that ECM that can't be repaired..
RJM Injection Tech — 60pin EEC-IV connector
RJM also sells all the pins and any small tools you may need.
Old 06-26-2013, 12:02 PM
fordf350camper
Hi the pin pulls out so needs to be soildered back but to do this all the all joints will have to be un soildered then back not sure if it can be done may have to take it to a auto electricman.Any idea what number 60 pin does
Old 06-26-2013, 01:00 PM
gman97005's Avatar
gman97005
It is one of several Negative Grounds for the ECM, connecting wire should be Black with White stripe
rpbf150
2009 - 2014 F150
08-23-2011 08:09 PM
murrmeister
29
07-17-2009 08:44 PM
timcpa
Car/truck Buying Advice
09-02-2006 12:58 AM
swish4323
2004 - 2008 F150
07-04-2006 07:59 PM
Quick Reply: Dont no what to do just broken my ecu who sells new ones
