Oil Leak...HELP
Old Jun 22, 2013 | 10:11 PM
kevlars's Avatar
kevlars
Oil Leak...HELP
My '98 B3000 has an oil leak. There is some oil up high on bell housing. So a buddy and I thought it might be the oil pressure sending unit. I replaced it. And still seems to be leaking.
Maybe valve covers? I was thinking rear main until we saw it on the bell housing. Valve covers don't seem to be leaking on the outside. Do they leak worse on the inside of the V?
Thanks in advance for your help!
Kevlars
Old Jun 23, 2013 | 06:32 AM
pawpaw's Avatar
pawpaw
Valve covers & CMP/cam sensor have been known to leak & have oil blow or drip high up on the bell housing. Has your PCV plumbing, or valve been replaced lately, if its clogged up, stuck, or sticking, it'll cause an engine over pressure condition, that'll cause the weakest gasket to blow, or weep.
More thoughts for consideration, let us know what you find.
EDIT: BTW Welcome to FTE!!!!
Old Jun 23, 2013 | 06:37 AM
kevlars's Avatar
kevlars
No, pawpaw, my PCV has not been changed lately. I need to. In fact, I have one, where is it located?
Thanks!
Old Jun 23, 2013 | 07:03 AM
pawpaw's Avatar
pawpaw
The PCV valve is located atop the drivers side firewall end of the valve cover. It may be hidden under some hoses.
Old Jun 23, 2013 | 07:11 AM
kevlars's Avatar
kevlars
Thanks! I'll get that changed. Hope it helps.
Thanks again, kevlars
Old Jun 23, 2013 | 09:52 AM
pawpaw's Avatar
pawpaw
If in your inspections for leak suspects you find its a valve cover gasket, you might try re-torqueing them to spec, as gaskets shrink over time & fasteners will loose their torque setting & that can cause a leak.
Does your cam sensor, located high up on the engine where the distributor used to be, passenger side, back close to the firewall, look like its wet with oil around its base, or is it making any untoward sounds, like a squeek????
honda250xtitan
1997 - 2003 F150
Mar 13, 2019 04:29 PM
danzigs
Feb 20, 2011 11:59 AM
ford71
Aug 31, 2007 11:33 AM
scootin
Mar 17, 2005 09:40 AM
