Check engine light 300 straight 6. Trouble code p0174
Old Jun 21, 2013 | 01:56 PM
joegeds's Avatar
joegeds
Fuel is too lean. It lists 10 possible causes, most have to do with air leaks. Air leaks after the MAF sensor location, air leaks in the intake and/or exhaust manifold, even says to check the dipstick not being on tight enough. Now, it also mentions the fuel pump not supplying enough fuel. One thing I noticed (and pointed out in another thread) is that the front fuel tank is selected, when I try to start it, it sputters and really struggles. Once I get it started (by using the rear fuel tank), I can switch to the front tank and it seems to run fine.
So, I thought I would start there since thats a visible problem. Is there a fuel pump in each tank? A sending unit? What parts would you start with to get the front tank to send enough fuel to the engine?
Old Jun 21, 2013 | 02:26 PM
timbersteel's Avatar
timbersteel
Sounds like weak fuel pump. "Sounds" is broad. Try cycling the key on off a few to several times, then try the front tank. If it starts and runs, most likely is weak fuel pump in front tank. Yes, it will throw a lean code if it's not keeping nominal pressure around 45-50 psi. Would be best to rent or buy fuel pressure tester and confirm.
Old Jun 21, 2013 | 02:42 PM
joegeds's Avatar
joegeds
Do you know if there is a test port on a 1996 300 straight 6? If so, where is it? If not, where else would i test the pressure? TIA.
Old Jun 21, 2013 | 03:12 PM
joegeds's Avatar
joegeds
Never mind - i found the port all by myself (after some interweb searching)!!! It is located on the fuel rail, behind the curve of the #6 cylinder. I think Auto-Zone or OReillys will let you"check out" a fuel pressure gauge. I'll have to do that, or just buy one.
Old Jun 21, 2013 | 03:14 PM
Yaga1973's Avatar
Yaga1973
Elder User - What???
The test port is on the very back of the fuel rail and can be a pain to get to as the upper plenum is in the way. The only way to access it is to reach in from the back between the firewall and the upper and lower plenums. There should be a black screw-on cap on the port and a standard sized Schrader valve inside it.
Hazmat 67
13
Dec 2, 2019 01:32 PM
DrFord
Oct 20, 2013 09:46 AM
albacore26
May 10, 2012 08:55 PM
1982fordf100
Jun 28, 2006 04:52 PM
ShadeTree49
Dec 18, 2004 08:06 PM
