Sponsored by: Real Truck
2005 F250 ABS Issues
Old Jun 21, 2013 | 01:08 PM
m1golf's Avatar
m1golf
2005 F250 4x4, manual locking hubs, ABS light stays on. Plugged it up, front sensors had a bad signal. Replaced both front sensors, still had light. Pulled out the sensors, cleaned the sensor rings the best we could with a little screwdriver. Installed the sensors, cleared the codes. Drove the truck a few miles, light came back on. Plugged it up, same codes. Removed the sensors and there was grease back on the sensor rings. Cleaned it up again, ran through the motions, drove it, light comes back on.
Is there supposed to be grease on the sensor ring? It keeps coming back in every time it is driven. My next guess would be the hub bearings are going bad? Thank you for any help, this has been frustrating.
Old Jun 22, 2013 | 06:57 AM
greentree ford's Avatar
greentree ford
did you check the vehicle speed sensor(on the transmission)
Old Jun 22, 2013 | 05:06 PM
Yahiko's Avatar
Yahiko
What code are you getting? Have you checked the VSS in the rear?
Sean
Old Jun 27, 2013 | 05:03 PM
Iron2's Avatar
Iron2
ABS Faults
I had a bad wheel bearing cause a ABS fault due to erratic signal from the sensor. The sensor is magnetic "Hall Effect", variations in the distance from the sensor and the sprocket can cause the sensors signal to distort. I would clear the ABS fault, it would come back only after making some turn left or right while driving.
Old Jun 27, 2013 | 05:18 PM
Yahiko's Avatar
Yahiko
Yep that will do it.
Also some times too much grease on the tone ring.
Tone Ring is the technical term for the sprocket.
Sean
Bigb6.0
Nov 29, 2017 09:58 PM
t_dub
Oct 13, 2016 03:52 PM
nickt916
Nov 20, 2012 06:06 PM
baitmaster
2004 - 2008 F150
19
May 3, 2011 04:58 PM
Empty Pockets
Aug 3, 2007 10:13 PM
