Sponsored by: Kumho
Leveling kit
Old Jan 5, 2007 | 02:32 PM
ibaneznik's Avatar
ibaneznik
Unhappy Leveling kit
i was wondering what leveling kit anyone would recomend. 'i have a 91 2wd f-150
Old Jan 5, 2007 | 06:26 PM
MustangGT221's Avatar
MustangGT221
To lift the front?
Any of the major suspension manufacturers have a leveling kit. Skyjacker has a 1.5-2" leveling kit.
It'll need an alignment with new camber adjustment bushings which can sometimes be hard to find. Local alignment shops don't usually have them.
Old Jan 5, 2007 | 06:32 PM
ibaneznik's Avatar
ibaneznik
do the alignment bushings lower my a-arms so that the top does not kick out and the wheel move inward when aligned. do the kits not come with them, i havent even looked at them yet.
Old Jan 7, 2007 | 09:59 PM
MustangGT221
The camber alignment bushings are in the upper ball joint area...between the ball joint and the knuckle. It sets the angle of the tire.
You do not have A-arms...A-arms are on wishbone suspensions and have an "A" shape. You have I-beams because they are in the shape of an "I".
When you lift this type of front suspension, you upset the camber angle. The camber angle is the / or \ tilt of the tire when you're looking at it from the front of the truck. For example, my 6" lift kit comes with brackets to lower the pivot points of the front suspension. By lowering this pivot point you reestablish the geometry of the suspension's camber. Those 2" kits are so small that you don't need to lower the pivot points, you can make it up in the camber bushings.
You can look up what the kits come with, I don't think they come with the camber bushings though.
It'll end up costing you a couple hundred bucks in parts/alignment and add labor if you're paying for it. Labor will add up real quick. Skyjacker probably has everything you need (including the bushings but probably separate from the leveling kit).
