help
Old Jun 19, 2013 | 05:07 PM
lostford100's Avatar
lostford100
help
I have a 79 f100 302 it tries to turn over but won't start. I'm getting no fire out of the coil. I changed it out still nothing. What can it be? Please help me it is all I got.
Old Jun 20, 2013 | 06:51 AM
glruff's Avatar
glruff
FTE Leadership Emeritus
Moved to tech forum for better help.
Old Jun 20, 2013 | 08:16 AM
fmc400's Avatar
fmc400
MSEE
You already asked this question in this forum too, but you never responded once people started trying to help you.
https://www.ford-trucks.com/forums/1250466-help.html
What's even more confusing is that your description of the problem in this thread differs from your description of the problem in your other thread. You're not off to a great start (no pun intended).
Old Jun 22, 2013 | 07:17 AM
lostford100
What's even more confusing is that your description of the problem in this thread differs from your description of the problem in your other thread. You're not off to a great start (no pun intended).[/ QUOTE]
Well I asked twice bc i didnt kmow if it went through and the same problem still presented itself in each statement so if you know your vehicles you would of known what i was talking about. Thanks for your help, but no thanks. I got it fixed. It was the ICM.
Old Jul 3, 2013 | 09:07 AM
fmc400's Avatar
fmc400
MSEE
Trust me, no one would have known what you were talking about because no one could understand what you were even saying.
Insulting folks within your first few posts certainly doesn't put you on the fast track for making friends on this forum.
Old Jul 3, 2013 | 11:22 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Agree with fmc400, post as much info as possible. Diagnosing problems by long distance is difficult at best, the more information, the better. All this is to try and help you.
As for your problem, you have the Dura-spark II system. Usually, but not always, when there is no spark, the control box mounted on the drivers side splash pan just ahead of the master cylinder is bad.
If you find that's the problem, pry open your wallet and spend the bucks for a genuine Motorcraft replacement. The offshore, Chinese POS you get at most chain stores can cause more problems than they cure. And they don't seem to last very long.
wetbiker
N. California Chapter
Aug 17, 2015 05:07 AM
fordpride
Jul 26, 2010 09:07 PM
Franklin2
Electrical Systems/Wiring
Mar 19, 2005 07:31 PM
Monsta
Jun 19, 2004 10:05 AM
JZ150
2004 - 2008 F150
Jun 17, 2004 10:22 AM
