1978 - 1996 Big Bronco
miss/lag issue
Old 06-18-2013, 01:10 PM
haaaammmmmm's Avatar
haaaammmmmm
haaaammmmmm is offline
miss/lag issue
Hello all, I have a 88 eddie b bronco with a 5.0, and I have a slight miss going down the road and now starts to take more cranking to start, so I replaced ignition coil, sparkplugs and wires, o2 sensor dist cap and rotor button and the starter, oh and the huge fuel filter on the frame, almost looked like there was another on motor, but is still acting up, what could be the cause? Would appreciate all input thx
Old 06-18-2013, 09:49 PM
greystreak92's Avatar
greystreak92
greystreak92 is offline
Let the onboard computer tell you what is ailing it. Run KOEO and KOER diagnostics tests and let the Code you retrieve determine what direction you pursue the issue. This will save you throwing more parts and money at it without knowing whether you have resolved it.
Old 06-19-2013, 01:05 AM
Cubawashere's Avatar
Cubawashere
Cubawashere is offline
also could try doing compression test, and see where the motor mechanically stands.... I've seen too many overheat one too many times and warp their heads, eventually developing head gasket leaks and such. But do start with Greystreak92's suggestion first, as there is less work involved. Good luck, and keep us updated!
Old 06-19-2013, 02:45 PM
haaaammmmmm
Ok, I guess I will go to a shop this weekend and see what they can pull, but as far as I'm aware its never been overheated and the motor only has 110xxx miles, in my opinion I'm leaning towards the egr valve Because it only does it at low rpms, I smell it running rich and I'm getting really bad milage, will let yall know what I find out, thanks for input
Old 06-19-2013, 03:30 PM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
Buy a Equus 3145 code reader or learn the paper clip method, both are easy and way cheaper than going to a shop.
Old 06-19-2013, 08:01 PM
Cubawashere
I agree with Encho...and the codes can be looked up yourself in the parts store, in the haynes manuals section. (I sometimes use the parts store as a library :-))
Old 06-19-2013, 08:06 PM
greystreak92
Yeah, you can look them up... but just knowing what they mean doesn't always give you the best idea as to how to troubleshoot them or even which one (if you get multiple fault Codes from the tests) to troubleshoot first. One fault Code can trigger a half-dozen or more OTHER Codes that may only be there because the computer is trying to compensate for the problems caused by the one that is the real problem. I'm just pointing this out because it is quite frequent that dealing with one code will clear up multiple issues that are causing other codes to trigger.
thomas avis
Engine Swaps
03-16-2018 06:05 PM
scouts5454
20
12-13-2014 09:42 AM
djblingbling1
1983 - 2012 Ranger & B-Series
07-05-2014 11:55 PM
CarCrazyRDM
08-14-2011 10:18 AM
ErrorS
22
07-13-2011 10:07 PM
Quick Reply: miss/lag issue
