MPG
Old Jun 27, 2013 | 09:21 PM
  #46
Grout-Scout's Avatar
Grout-Scout
Originally Posted by gsxr1300
For me regens never drop my average mpg enough to notice, my instant mpg drops for about 10 miles but not the average.
Lucky you! I get the freaking things every 150-200 miles and they never come on when I'm actually driving a long distance.
Old Jun 27, 2013 | 09:41 PM
  #47
Firekite's Avatar
Firekite
Regens? As compared to using DEF to clean the exhaust filter?
Old Jun 28, 2013 | 07:16 AM
  #48
gsxr1300's Avatar
gsxr1300
Def has nothing to do with cleaning the exhaust filter
DEF is injected into the exhaust to reduce NOx emissions.
Old Jun 28, 2013 | 04:59 PM
  #49
Adobe 11SD's Avatar
Adobe 11SD
I guess that depends on when regen starts - relative to when you reset LOM, right?
In other words if I am on a 1500 mile trip and have driven 1000 miles, I won't see the average MPG change either as long as I don't reset the LOM. But, if I just left home (reset the LOM for the trip) and am 30 miles down the road when it decides to regen, I will certainly see the average MPG go down. I typically get 12 MPG during regen during "normal" driving conditions.
Old Jun 29, 2013 | 01:20 AM
  #50
Firekite's Avatar
Firekite
So you're saying when the little info system comes up and says "Cleaning Exhaust Filter" it's doing a "regen"? Because I have noticed no difference in rpm, boost, mpg, etc while that's going on. How long does it last, and what are the symptoms you can see when it's going on?
EDIT: More info confirming what you're saying from Wikipedia:
Originally Posted by Wikipedia
Diesel engines run with a lean (overstoichiometric) air-to-fuel ratio to ensure the combustion of soot and prevent unburnt fuel from being emitted. The excess of oxygen necessarily leads to generation of nitrogen oxides (NOx), which are harmful pollutants, from the nitrogen in the air. Selective catalytic reduction is used to reduce the amount of NOx released into the air using DEF. Diesel exhaust fluid (from the DEF tank located inDiesel vehicles) is injected into the exhaust as it moves through the engine where it vaporizes and decomposes to form ammonia and carbon dioxide. With the SCR catalyst, the NOx are catalytically reduced by the ammonia (NH3) into water (H2O) and nitrogen (N2), which are both harmless and are released through the exhaust.
DEF is stored in a tank on board the vehicle, and injected into the exhaust stream by a metering system at a rate of 2% of diesel consumption volume (4-6% in Europe).
Old Jun 29, 2013 | 07:48 AM
  #51
Grout-Scout
Fire, if you never ever reset the mpg meter then the number won't change much during a regen since its using a long history of averaging. But if you reset the mpg meter at every fill up and a regen comes on it will drop that sucker by at least 1 mpg (at least that's what mine does).
My truck also like yours doesn't show any signs of a regen other than the message (well, the dropping mpg meter shows it but I don't reset the trip log anymore). Every now and then I have noticed at the end of a regen my truck will make a roar sound, kinda like a fan clutch locking up makes. I don't know the exact length of time or miles but someone told me its about 10 minutes. I seem to be getting them around every 150-200 miles.
Old Jun 29, 2013 | 11:26 AM
  #52
wtrlogd's Avatar
wtrlogd
Originally Posted by Painted Horse
My mpg has been as low as 7.5mpg and as high as 23mpg.
It really depends on what you are doing.
65 mph on a 300 mile long flat hiway will get you in the 20's
80 mph on a 300 mile long hiway drive will get you 18's
city driving will get you 13-15 mpg
Towing a large 5ver in a head wind will get you 7.5mpg.
Towing same trailer with out the headwind will get you 10.5 mpg
My numbers are very close to this, although at a few less miles per hour, maybe due to mine having the 3.55 rear.
Head wind is much more of a factor than weight. Better mpg with a low flatbed at 13K than with a fifth wheel at 8K.
Old Jun 29, 2013 | 03:01 PM
  #53
2ndStroke's Avatar
2ndStroke
Old Jun 30, 2013 | 01:08 AM
  #54
Firekite's Avatar
Firekite
I keep a pretty close eye on the instant readout, and I don't notice anything unusual, like a major drop...
Old Jun 30, 2013 | 07:20 AM
  #55
Adobe 11SD's Avatar
Adobe 11SD
That's odd, probably in a good way.
I reset the average MPG and trip odometer on each fill up and even if I don't see the cleaning exhaust message I can tell that it is in regen. Obviously it is less noticeable if I am getting low on fuel because of the number of miles that I have driven since filling up.
Each truck is different and driven differently, so who knows.
I get 3-5 MPG better than a friend that purchased a 2012. But, I'll confess that most of the time I drive to achieve the best MPG I can. For instance I try to time traffic lights, let off the accelerator a good distance before the I need to stop and down shift manually when approaching a stop light/sign. The theory being -- I already invested in the fuel it took to get up to speed, I don't want to invest more getting to the light/sign faster just to sit there idling while waiting for the green light.
Old Jun 30, 2013 | 08:04 AM
  #56
U235Fishin''s Avatar
U235Fishin'
ScanGaugeII & Regen
I have found that besides an unusually low mpg reading on the dash display while in a regen cycle, my ScanGauge II mpg reads an unusually high mpg reading. Go figure. As soon as the regen cycle is complete the two pretty much indicate about the same value.
Old Jun 30, 2013 | 08:30 AM
  #57
Kjewer1's Avatar
Kjewer1
That's good theory. Turning fuel into brake dust doesn't get you anywhere.
All modern vehicles cut fuel while coasting (above idle rpm), and this truck is real good at it with the converter being locked up above 900 rpm. The more distance you can cover coasting, the better your mileage will be. Even if you floor the diesel pedal mileage can only drop from ~20 to 0. When coasting it goes up from ~20 to infinity. In other words, it can rise a lot farther than it can fall, and this can be used to get the average way up.
Old Jun 30, 2013 | 08:53 AM
  #58
Idaho Slim's Avatar
Idaho Slim
Yeah I sure wish everybody would use real world driving while reporting their mileage, telling people inflated numbers causes others misery. When I first came onto this site I was reading "I get 17-19 city & 19-23 hwy". I now know those numbers are bogus and many here don't do a hand calc'd real number on the entire tank. Sad, almost like telling half the story and not the whole story.
Most honest post in this thread.
Old Jun 30, 2013 | 10:33 AM
  #59
Kjewer1's Avatar
Kjewer1
To say that people that get crappy mileage are just more honest than people that get better mileage is absurd. The people that get poor mileage are always butt hurt, doesn't matter what type of vehicle or what forum it is. My GF gets pissed when I get 10 more mpg on a given route than she can, or tank average, but she doesn't call me a liar for it.
Old Jun 30, 2013 | 01:40 PM
  #60
Idaho Slim's Avatar
Idaho Slim
You are missing the point, had nothing to do with calling someone a liar, to me his post means reporting your ACTUAL mpg hand calculating it from the point of filling up, starting the car and keeping track of it the full time of use on the tank, not "getting up to hwy speed, driving like a grandpa/grandma" and saying; "Heck I get 25.6 mpg hwy etc" ............ hence his use of the term "REAL WORLD".
