E350Cube
Old Jun 17, 2013 | 09:06 PM
94Sport5sp's Avatar
94Sport5sp
E350Cube
Hi:
I just recently acquired an E350 Cube Van and I am looking for a forum where I can get answers.
Unit is a 91 with a diesel, automatic transmission, has single axle with dual wheels and a 16 foot enclosed box.
Thanks
Old Jun 17, 2013 | 09:24 PM
blue924.9's Avatar
blue924.9
okay............... so what do you want to know
Old Jun 17, 2013 | 09:50 PM
White 97 xlt's Avatar
White 97 xlt
Here are a couple more places you might get some useful knowledge from:
Pre-Power Stroke Diesel (7.3L IDI & 6.9L) - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans - Ford Truck Enthusiasts Forums
Old Jun 17, 2013 | 10:47 PM
94Sport5sp's Avatar
94Sport5sp
Hi blue924.9:
I would like to determine what motor (size) is in the van. As I am new to diesel's in general I would like information on maintaining. I see on the dash a light that says "Wait to Start" and when it goes out I start the truck. Is this some pretesting?
I also need to fix the RABS as the warning light stays on all the time. On my 94 Explorer I could read the code using the "Check" light. I assume there is something similar for this unit.
Generally I would like to learn more so I can service this unit. I have talked to others who say "Do Not Run Out of Fuel". So if I do how do I restart?
Thanks
Old Jun 17, 2013 | 10:50 PM
94Sport5sp's Avatar
94Sport5sp
Hi White 97 xlt:
Thanks for the links.
Old Jun 17, 2013 | 11:51 PM
IDIDieselJohn's Avatar
IDIDieselJohn
The Wait to Start light, is the Glow Plugs warming up the air in the pre chambers (where fuel is injected) to start a cold engine.
Diesel fires by heat and compression, and use no spark like a gas engine with spark plugs to ignite the fuel. So it needs heat to start up a cold engine in order to make ignition.
Others that told you not to run out of fuel, is because these older diesels have mechanical fuel pumps, run off the cam of the engine. The engine needs to be turning in order for fuel to be pumped to the engine.
If you run out of fuel, you loose your "prime".
When that happens, you'll need to crank the engine over for ever for the mechanical fuel pump to pump fuel back up to the engine from the fuel tank.
Caution! DO NOT crank for more than 20 seconds at a time, with a 2 full minute cool down time for the starter....if you don't want to be replacing a 250$ Starter!
The engine you have a 7.3L IDI (InDirect Injected) Diesel, with the E4OD (4 speed automatic, with the OD cancel switch on the dash, just to the left of the steering column).
If it doesn't have the OD button, it will be the C6 3 speed transmission.
Old Jun 18, 2013 | 08:09 AM
94Sport5sp's Avatar
94Sport5sp
Hi IDIDieselJohn:
Thanks for the information.
Is that also the clicking sound I hear after the Wait to Start light goes out and before I engage the starter?
Sounds like my old international when it runs out of gasoline. How about the fuel filter. I understand that all diesels have filters that need to be changed regularly?
Yes it has the OD cancel switch on the dash. I assume that this is for when I have a fairly heavy load on the truck to prevent the OD from kicking in.
Thanks for helping me understand.
Old Jun 18, 2013 | 12:40 PM
IDIDieselJohn
Yes the clicking is the glow plug relay cycling the plugs after the light goes out. It cycles for about a minute after the engine is running to keep it running smooth.
Yes your fuel filter will be on top of the engine, to the drivers side, front, behind the A/C compressor if you have AC. That should be changed every 2 years or 20k miles, witch ever comes first.
And yes, cancel OD when you towing very heavy, or in hills. Or whenever the tranny goes in and out of OD.
Old Jun 18, 2013 | 08:18 PM
94Sport5sp's Avatar
94Sport5sp
Hi IDIDieselJohn:
Now on to fixing.
lawwich
Apr 6, 2015 01:36 PM
Allison28
Mar 30, 2011 11:20 PM
afirecat
General Automotive Discussion
Aug 17, 2005 06:25 PM
