Toyota P/S box help
Old Jun 16, 2013 | 10:27 PM
Englishbob's Avatar
Englishbob
Toyota P/S box help
Chaps and Chapesses,
do any of you that did the Toyota p/s box conversion have pics of the brass olive type fittings that fit in the hose connection holes?
Thanks
Old Jun 17, 2013 | 01:45 AM
1oldtimer's Avatar
1oldtimer
Are you talking about the fittings for the hoses or the tube seat for the fittings.
fittings:
Toyota Power Steering Fitting
Tube seat:
Power Steering Pressure Hose Bubble Flare - JTOutfitters
Old Jun 17, 2013 | 08:48 AM
AXracer's Avatar
AXracer
Be careful, the pressure side hose port is a standard 16mm size, but the return fitting is a OEM Toyota only non-standard 17mm size. Mid fifty has a hose fitting conversion kit with a custom made 17mm fitting. Gotta show Gotta Show Products Home Page Featuring Hot Rod Plumbing sells a SS braid hose kit for this conversion that contains their own properly sized SS banjo fittings for the box connection ends.
Old Jun 17, 2013 | 01:28 PM
Englishbob's Avatar
Englishbob
fittings:
Tube seat:
Thank you I had the box rebuilt and the shop lost the flare and I tried describing it but to no avail.
Bob
1949f1
Oct 31, 2017 08:38 AM
jaye
Aug 6, 2008 05:50 PM
John Boyd
20
May 4, 2006 06:30 PM
rustyropes
Jan 31, 2004 10:22 AM
