Front End Not Lowering Evenly
A little while ago I fitted new front coils to my '79 F100, at that time I also fitted a pair of 3" drop DJM Dream Beams.
After finishing the job I noticed the camber of the front wheels seemed to be a fair way positive (you could easily see that the top of the wheels were leaning out).
I had a front end alignment done and the analysis came back as 2 degrees 15 minutes on the left hand wheel (my passenger side here in Australia) and 2 degrees 44 minutes on the right hand (drivers) side.
I'd been driving it that way for a while (even though the front end felt pretty ordinary) but I recently noticed the tyres were starting to scrub out on the outside so I decided to get my act together and cut some of the coil until the camber was somewhere about 0 degrees (I've been advised that stock camber is -5/8 degrees +/- 3/8 degrees).
I found a piece of 20mm steel angle, laid it on an engineering table so I could see that it was fairly straight and flat and also bought a magnetic angle protractor so I could park the truck in my shed on a reasonably flat and level surface and measure the camber as I shortened the coils. I know the camber measurement won't be particularly accurate but I wanted to get it as close as I could and then I'll get another front end alignment done.
Before I started I checked that both front tyres were at the same pressure and then measured the camber angles and also distance between the front beams and a point on the rebound rubber bracket on either side.
The measurements were as follows:
- Passenger side +1.5 degrees and 111mm
- Drivers side +2.5 degrees and 97mm
For the first cut I removed the same amount of material from either coil, re-installed them and then, after driving down the road to make sure everything was settled, took a second set of measurements.
They were:
- Passenger side +1.5 degrees and 108mm
- Driver's side +2.0 degrees and 94mm
The measurements now are:
- Passenger side +1.0 degrees 104mm
- Driver's side +1.5 degrees 92mm
After all that what I'm asking is does anyone have any idea what could be causing the front end to drop unevenly? The distance on the driver's side should be evening up with the passenger side after having more of the coil removed.
I'm having some doubts about the chassis itself, I've had to space the driver's side radiator core support by about 10mm to raise it to level it up and I've also had to loosen the whole front clip and pull it across towards the driver's side to have it sit more evenly over the front wheels. I don't think all is right with that because to get the clip to sit evenly leaves a very uneven gap between the back edge of the bonnet and the cowl panel on the cab (much bigger gap on the passenger side than the driver's side).
Any input would be much appreciated.
I've found a truck alignment business near me that can set I beams but my understanding is that because the DJM beams are fabricated from hollow section tube that they can't be bent as they will deform.
The stock beams are solid and can be set and with the way the drop beams feel I've been considering refitting my stock items and going that way. My concern is that without the 3 inch drop that you get with the drop beams I may run out of suspension travel before I get to the ride height I want using the stock beams.
I never knew how the drop beams were constructed , sorry to hear that .
I cut another section out of both coils this morning and I've now got the passenger side very close to 0 degrees (maybe still a touch positive) and the driver's side seems to be about 1 degree positive. The driver's side of the front clip still seems to be lower though and that side has less suspension travel so I still don't know what's going on there.
I'll take the truck in next week and get the alignment checked properly and see exactly where it's at.
i wonder if a fabrication shop could steer you in the right direction.
perhaps there is a way to use a regular pipe die in the alignment shop's equipment.
just a thought
I'm not sure which shims you're referring to.
I'd like to get some radius arms made with an offset in them but here in Australia something like that would require engineering certification to be legal and engineer's certificates cost literally thousands of dollars (a friend of mine had one issued for some work he did on an old wagon he restored and that cost him $1200 and there wasn't a whole lot of mods that he had to get certified).
If I was going to get into the hassle of engineer's certificates I'd get a chassis notch done for the rear end but I'm trying to avoid the extra cost and trouble.
I've already got a stack of 5 of them under the driver's side core support mount and looking at the clip and bumper from the front of the vehicle you can see that the driver's side is sitting up in relation to the bumper bar.
I'm planning on hopefully taking the vehicle off the road in a few months for a body off restoration, when it comes time for re-assembly maybe I'll figure out what's going on then. My priority at this point is to get the front end geometry correct and go from there.
