Sponsored by: Real Truck
Replacing Fuel Injectors?
Old Jun 13, 2013 | 05:44 PM
rascalboy's Avatar
rascalboy
Hey all! I'm new here, and new to mechanical stuff in general so... I apologize in advance if I ask anyone to dumb things down for me.
I have an '01 F250 Superduty XLT Turbodiesel 4x4 7.3L truck with 275k miles. It's been horribly difficult to start in cold weather recently, and we've narrowed it down to the fuel injectors. I'm told I ought to get refurbished ones and replace those (and then the wire harness and glowplugs, etc) and the O-rings. However, as I'm sure everyone knows, that's going to run me about $1200-$2000 in parts alone. Maybe $3500-ish if I pay someone to do that.
I've heard about just manually cleaning the fuel injectors and then replacing the O-rings (soak them in solution and blow all the junk out a few times) but I'm wondering how effective that would be on my diesel truck. I was told that opening up and removing the injectors will disturb that part of the truck and it's hard enough to get to anyway, so I should just replace them.
Any input?
Old Jun 13, 2013 | 07:07 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Pulling and cleaning the injectors won't do any good. You need remanufactured or new units. The nozzles are probably worn and the plungers and barrels may have some scoring. Rosewood Diesel can usually rebuild your original sticks for about $900-$1000 and that includes new nozzles, springs and o-rings and the occasional plunger and barrel. I've done this on two of my trucks and it's worked out great so far.
It's a great idea to replace your glow plugs while you are in there. The valve cover and injector harnesses are reusable so there is no need to replace those unless they are damaged.
Getting to the injectors isn't really that hard. Here is a thread that may help with some tips.
https://www.ford-trucks.com/forums/1...l#post10438805
sju96ford
Jun 27, 2011 02:09 PM
MikeDehner
1978 - 1996 Big Bronco
Jun 28, 2010 07:51 PM
oldproudvet
Jun 25, 2008 02:37 PM
farmb0y
Dec 12, 2007 09:51 PM
diggy
Aerostar
Feb 4, 2004 10:18 AM
