General Automotive Discussion
AC running
Old Jun 12, 2013 | 08:44 PM
motor home's Avatar
motor home
AC running
Is it normal for the AC to run when useing the heater on a 97 class A motor home with a 460 Ford engine?
Old Jun 13, 2013 | 06:01 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
Welcome to FTE! Moving to general automotive.
Old Jun 13, 2013 | 07:49 AM
thomabb's Avatar
thomabb
The AC pump will kick in at times that don't initially seem to make sense. The compressor will run, for example, when the defrost position is selected even if the heat is turned all the way up. This helps dry the air and exercise the AC system so the seals don't dry up.
Old Jun 13, 2013 | 08:09 PM
projectSHO89's Avatar
projectSHO89
On most Fords, the A/C will run in all switch settings except OFF, VENT, and FLOOR.
Niki Farmgirl
Jun 9, 2018 06:21 AM
bnovak
Aug 1, 2009 10:54 AM
mjlevi
Oct 24, 2006 05:43 AM
Chance_Thomas
May 10, 2006 10:18 PM
wipper
Sep 16, 2004 10:33 PM
