Sponsored by: Real Truck
Fuel Pump Issue?
Old Jun 12, 2013 | 07:50 PM
Mshiff62's Avatar
Mshiff62
Fuel Pump Issue?
Ok, I have a 2004 F250 FX4 4wd 5.4L with almost 160K miles.
Sometimes, mostly when it's hot, and I go to restart it, it will crank and crank and crank, so I let off and then try again and it will start. Then other times I will have to do it 3-5 times before it starts, or it will start with real low RPM's for a second then cut out. I have been told this truck does NOT have a Fuel Pump Driver Module (My previous F-150 did). So I'm thinking the fuel pump is just temperamental. Anyone have this issue or replaced a fuel pump before? What brands, places, etc. are good to buy at a decent price?
I tried to look online and was confused about a "midship, rear, and center tank". All I know is my truck is an extended cab and has about a 29 gallon tank.
All help is much appreciated
Old Jun 12, 2013 | 08:00 PM
redford's Avatar
redford
FTE Leadership Emeritus
Have you checked the fuel pressure?
Old Jun 12, 2013 | 08:12 PM
Mshiff62's Avatar
Mshiff62
No I have not, can that be done at the rail with a handheld gauge?
Old Jun 13, 2013 | 06:06 AM
redford's Avatar
redford
Yes, it can. The reason I ask is that there are a lot of things that could cause the symptoms you are seeing. Throwing parts at the truck without doing some troubleshooting is a waste of money.
Old Jun 13, 2013 | 06:27 AM
Mshiff62's Avatar
Mshiff62
I see what you're saying. Hmm, only reason I was going to do a pump was this happened to my F150 and it solved it. I will have to check the fuel press though I'll go buy a gauge.
Old Jun 13, 2013 | 06:35 AM
redford's Avatar
redford
Honestly, my first thought was not the fuel pump. I would check and clean the IAC, clean the MAF and check for possible vacuum leaks.
Old Jun 13, 2013 | 07:38 PM
Mshiff62's Avatar
Mshiff62
I have done all of that within the last few months. Appears to all be ok. That was why I was thinking fuel pump or fuel pump relay?
bergy 2000
Modular V10 (6.8l)
13
May 16, 2023 02:49 PM
Locdoctn1
Oct 24, 2018 07:50 AM
870
Jul 19, 2008 08:42 AM
scottie2hottie
Feb 10, 2007 09:06 AM
chrisrog
Jul 13, 2001 12:15 AM
