Going to "flush it" today..
Old Jun 12, 2013 | 03:21 PM
droffan's Avatar
droffan
should the thermo be changed out also at this time. also i am not sure where to locate the block plugs. on each side or just one, what and where do i look? size of bolt?
Old Jun 12, 2013 | 04:15 PM
ndlawrence's Avatar
ndlawrence
Here's a walkthrough. Pretty easy to find the drivers side plug, you have to remove the starter for the passenger side plug. https://www.ford-trucks.com/forums/9...nge-101-a.html
Old Jun 12, 2013 | 05:13 PM
Enduroman's Avatar
Enduroman
I did mine a month or so ago. The starter was more difficult to get out than I was expecting. One of the 3 bolts (i think 13mm??) was a bugger. Was very glad to have an air ratchet. I was also glad to have a fumoto valve to install in place of that block plug so that I don't have to pull the starter again, next time I flush - which will likely be soon. Good luck
Ambulancewarrior
Apr 30, 2019 07:23 PM
Sullid01
Aug 5, 2013 07:42 AM
Piolet
Feb 19, 2013 08:26 PM
schmidty99
19
Aug 24, 2006 09:05 AM
BigBlue2
Sep 9, 2004 11:32 PM
