A/C runs
Old Jun 11, 2013 | 04:27 PM
jspence105's Avatar
jspence105
A/C runs
I noticed that my A/C runs all the time. Is this normal for an Ex? I'm wondering if it's the result of the after market DRL that were installed.
Old Jun 11, 2013 | 04:51 PM
Archion's Avatar
Archion
Veteran: Marine Corps
The fan or the compressor?
Old Jun 11, 2013 | 05:52 PM
jspence105's Avatar
jspence105
I guess my description was vague. The compressor runs as it would normally run when it is set to AC in all positions except for the off position, where it turns off. I just happened to notice it over the last couple of days, it's been humid but not hot so I haven't had the AC on, it selector was set in the vent position. I noticed a lot of water under it and looked into what was going one and found the compressor running.
Old Jun 11, 2013 | 08:44 PM
Archion's Avatar
Archion
And you had it on dash only vent right, split level still runs the compressor. I found that out a few weeks back.
Old Jun 11, 2013 | 09:14 PM
jspence105's Avatar
jspence105
Good to know. I'll have to get the kids to flip through the settings and find out what ones the compressor runs on.
Thanks
Old Jun 12, 2013 | 05:18 AM
Archion's Avatar
Archion
It should run on everything but dash, floor and off. Stupid of Ford actually. I've been thinking about putting a kill switch in the panel. I think it's the purple wire coming off the control head. I'd have to pull up alldata again and look.
Old Jun 12, 2013 | 04:04 PM
jspence105's Avatar
jspence105
You called it, I'm surprised that it would run in the split position. I assumed that would be a safe one.
Old Jun 12, 2013 | 04:27 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Seriously?
Great, I might as well be using the stupid AC then. Cutoff switch added to the list.
Old Jun 12, 2013 | 05:29 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It runs to reduce humidity. If you don't like that you could add a kill switch.
Old Jun 12, 2013 | 09:28 PM
Archion's Avatar
Archion
Yeah, surprised me too... I'll do it when I put in the remote power supply for the sat radio, that'll be the next time I have the dash apart. Glad it wasn't anything $erious like a module..
Old Jun 13, 2013 | 01:53 AM
Stewart_H's Avatar
Stewart_H
I'm surprised this is...well...that this still comes as a surprise to anyone.
Ford's have been like this for a long time and I guess I figured it was something everyone knew about.
Stewart
Old Jun 13, 2013 | 02:46 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
I use my vents all the time out here. It rains alot, so I can't open the windows, but it isn't hot enough for AC. I figured the vent was NOT running the AC. So I'd still get cooler air, but no performance hits from the compressor cycling.
Same reason I hate running defrost. If I wanted the AC compressor on, I'd turn the stupid thing on
Old Jun 13, 2013 | 04:15 AM
jspence105's Avatar
jspence105
Stewart
This is the first time I've noticed it and I haven't driven anything but a ford since 1995. They have always run the AC in the defrost positions as well as the AC positions.
Old Jun 13, 2013 | 05:14 AM
Archion's Avatar
Archion
Stewart
That's the thing. Not all of them have. My 99 Mustang doesn't do it. My 06 Mustang didn't do it. And of course our old Focus and the Escape has a kill switch...
Old Jun 13, 2013 | 05:17 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
my 2009 Mustang Bullitt didn't do it either
