94 f150 dead
Old Jun 14, 2013 | 10:16 PM
orange powerstroke's Avatar
orange powerstroke
Originally Posted by kermmydog
Thanks for the correction.
Craig
Pretty much convinced its pumps. Gonna pull the tanks tomorrow after work. There are fluctuations in fuel pressure. Replaced the pressure regulator, no change. The pressure is 34-35 it will start if the key is cycled a few times, but dies without warning due to a pressure drop. Let's hope this gets it. Will let you know.
Tony
Old Jun 15, 2013 | 05:10 PM
orange powerstroke
Tony
It's not the pump.. what's next?
Old Jun 15, 2013 | 06:22 PM
Nathan Plemons's Avatar
Nathan Plemons
Sticking / Leaking injectors?
Old Jun 16, 2013 | 09:11 AM
subford's Avatar
subford
The key being cycled will tell you nothing.
To check the fuel system you need to hook up the fuel gauge, ground pin #6 of the self-test plug or short pin#2 to pin#6 and turn on the key.
The selected fuel pump should be 42-45psi.
Turn off the key and the fuel pressure should drop a few psi and then drop very very slowly and down to zero overnight.
The fuel pressure for a 302 should be 31-34psi at idle depending on the vacuum at the FPR & 40-42psi at WOT.
It should also be 42 to 45psi if you pull the vacuum line off the FPR while the engine is idling.
Old Jun 16, 2013 | 10:42 AM
orange powerstroke
Started and died pulled codes again. Ran through all systems. Last code thrown PIP SENSOR. Never thrown a 211 code before, even a ghost code guess it had to fail completely. Now change O2 ans should be good to go. Thanks for the help. New fuel pump, distrubtor, Fpr(failed), coil(weak) TFI, cap&rotor, and IAC. New clutch, master cylinder, and slave cylinder. Almost new except the rust.
Old Jun 16, 2013 | 11:29 AM
subford's Avatar
subford
I would change the PIP sensor. Maybe the the PIP sensor was the only thing wrong with it to start with.
Old Jun 16, 2013 | 11:35 AM
orange powerstroke
I already changed it out and it runs.
Old Jun 16, 2013 | 11:53 AM
Encho's Avatar
Encho
The Southernmost Mod
What did you change? which was the cause? if you're more clear you'll be helping others with similar problems.
Stratifiedjoe
Jun 22, 2016 01:06 AM
Nickster225
Jul 28, 2014 07:57 AM
diesel-fitter-bum01
2004 - 2008 F150
Nov 13, 2011 10:59 AM
dsthubbins
Jul 15, 2007 07:22 AM
hibbing94F150
Sep 27, 2004 01:01 PM
