IBC issues
Old Jun 13, 2013 | 08:27 PM
RV_Tech's Avatar
RV_Tech
Originally Posted by FloridaStroker
I guess I know where my next stop is.
Stroker,
My overriding thought in all troubleshooting situations is to go with the simplest things first. I spent some years trying to reinvent electricity in my troubleshooting before finally accepting the fact it is very seldom the case the solution to the problem at hand is complex. The most common problem with braking systems is the seven-pin on the back of the truck and that probably outnumbers all other problems by an overwhelming majority. yes, other things can happen, but the first thing I want to know is do I have voltage to the brake pin.
Unless you look at the back of your plug and the wires are butchered, I doubt the pins are miswired and given the fact your trailer lights are all working correctly, how it that even possible? You have every other lead in the seven pin accounted for with the lighting.
Pop off the back of the seven pin under your truck and put a voltage meter on the lead to the brake pin. Have someone work the manual slide. Do you have voltage or not?
Steve
Old Jun 14, 2013 | 12:29 PM
TexasRebel's Avatar
TexasRebel
all pins except two.... the Center pin, Reverse lights/aux2, and the Aux 1 pin.
I've known folks to switch the brake line with an aux line to engage the trailer brakes if somebody with a regularly wired pickup tried to drive off with it.
Old Jun 14, 2013 | 10:55 PM
BigMix's Avatar
BigMix
You may want to check your ground(again if you already have). On a few other vehicles this has usually been my problem. Having a bad ground (at a point of connection, a frayed wire, or a small hole in the wire's insulation) can cause a multitude of different problems. It has caused for me "trailer not connected" and the trailer brakes to lockup if I turned on my lights.
Old Jun 14, 2013 | 11:59 PM
FloridaStroker's Avatar
FloridaStroker
SUCCESS!!!! Broke the plug apart on the truck, wasn't looking too bad but cleaned it up anyways. Put everything back together. Try out the fancy new plug tester (with LEDs) and got a reading. Loved the tester due to the fact that the higher the gain the brighter the LED for the brake lights up. Well anyways back to the story, hooked the trailer up, started to pull out of the driveway, hit the manual slider and the brakes locked up. Took it out for a spin and everytime I hit the brakes I could feel an ever so sight of a tug from the trailer. Thanks guys for all the help.
Old Jun 15, 2013 | 07:22 AM
RV_Tech's Avatar
RV_Tech
Good job, sometimes the right tool makes all the difference in the world.
Safe travels,
Steve
Reveille
Nov 22, 2020 09:40 PM
DGMFORD
Sep 30, 2020 08:59 PM
MKRemi
6.7L Power Stroke Diesel
22
Apr 12, 2012 07:48 PM
Hurricane Ditka
Aug 23, 2011 10:49 AM
richsoucie
Aug 29, 2008 02:20 PM
