Temperature Sender location.
Old Jun 11, 2013 | 11:37 AM
lm987's Avatar
lm987
Greetings all,
I installed a used Edelbrock Performer intake manifold on my 302 engine in my 1950 ford F-1. Because I couldn't get the plug out where the temperature sender is normally located (adjacent to the distributor) I had to locate it towards the rear of the manifold. Will this location have a major effect on the temperature reading ??
Thanks
Old Jun 11, 2013 | 01:03 PM
baddad457's Avatar
baddad457
No, it should be fine. I would prefer it at the front, but the reading will be pretty close to accurate. You can always install a pipe "Tee" in the heater hose location in the intake's front and install the sender there too. If you do, use brass fittings, not iron or steel.
Old Jun 12, 2013 | 10:32 AM
lm987's Avatar
lm987
Temperature sender location
Thanks for the info and god idea on a more accurate location.
lm987
Jolly Roger Joe
18
Oct 17, 2017 04:28 PM
whiteisright
Oct 20, 2011 02:15 PM
ford1puller
Sep 2, 2009 07:17 AM
santacruzf250
Jun 9, 2009 09:07 PM
