Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Escape shift problem
Old Jun 11, 2013 | 10:24 AM
pabear89's Avatar
pabear89
2001 Escape V6 auto 2wd.
Has been driving fine and out of the blue it started not going into 3rd.
The Od light started flashing and I hooked my OBD2 reader to it.
No codes appear on reader. But the trans won't shift up to 3rd, the rpms just race but 1st and 2nd shift fine also r works.
Hoping for a easy fix and not a rebuild, Any help would be great.
Thanks
Old Jun 11, 2013 | 12:31 PM
projectSHO89's Avatar
projectSHO89
Rebuild it, it's busted.
Old Jun 14, 2013 | 12:12 AM
pabear89's Avatar
pabear89
...Not what I wanted to hear, wonder what that will cost?
Old Jun 14, 2013 | 05:20 AM
projectSHO89
More than you want to hear.
Old Jun 14, 2013 | 09:19 AM
tomw's Avatar
tomw
The blinking light indicating transmission problems will NOT hang around once the vehicle has been turned off. There is no 'memory' in the control, so it forgets it had a problem.
The direct clutch is not applying, so you over-rev. It applies in 3rd and OD. Checking the service manual, I believer it is controlled by a solenoid. The line pressure is also controlled electronically.
You may have a bad solenoid, or even loose connections. It may not be 'busted' as much as sho indicated, and may cost a lot less than stated.
Most times when a transmission is in the process of dying, you'll get late shifts, engine rpm 'flare' when it tries to upshift, slow engagement, and a big pile of worry that you might not make it home...
If you didn't have any of those symptoms, I'd take it to a reliable independent when the light is flashing and let them read the code. I just looked at the 2005 model year as I don't go that far back, but the same transmission, with improvements, has been used since introduction.
tom
Old Jun 17, 2013 | 09:37 AM
pabear89's Avatar
pabear89
Had code reader hooked up while test driving it, No codes present.
Where is this sol located? inside or outside of the trans.
Sadley sitting on the fence about this, The car is in good shape but dropping 3k for a trans is about what the Kbb says its worth.
Old Jun 17, 2013 | 11:09 AM
tomw's Avatar
tomw
The shift solenoids are located inside the front 'pan' I believe. They are attached to the valve body as they have to direct fluid flow. I think transmission shops can test the operation of the solenoids, and if you have access to a wiring diagram, you can test them yourself for shorts or opens. I read somewhere that ChryCo transmissions could have their solenoids operated by a test box of sorts, so suspect the FoMoCo Rotunda branch would have similar test equipment.
Generally as noted, you have a bit of warning before things totally quit, so I would be looking at something that can break instantly with no fore-warning symptoms. Solenoids fit that bill.
tom
Old Jul 5, 2013 | 11:33 AM
pabear89's Avatar
pabear89
Update
Well it was worst case problem with trans.
Now 2750.00 later it has newly rebuilt trans and new convertor.
But having 194000 hard miles on it with no troubles or fluid changes,
I guess it was time.
Old Jul 5, 2013 | 05:13 PM
projectSHO89
Yeah, not bad for a CD4E.
My 07 Mariner's tranny busted a couple of weeks after we bought it (O/D band broke), but, luckily it was just barely still in warranty. It's up to 105K miles now with no further tranny problems.
My 98 Conturd went through a valve body and torque converter in '06 at 130K miles. It's now at 235K miles and still running well enough to use as my DD.
AAA membership and a cell phone....
Old Jul 5, 2013 | 07:35 PM
2escapefmt's Avatar
2escapefmt
just tears at the heart of any worth while auto person to hear 194,00 hard miles and no care whatsoever to the life blood of a AT
death by neglect- as in life
Old Jul 6, 2013 | 06:39 AM
projectSHO89
There is no evidence that such is the case.
Old Jul 8, 2013 | 06:16 PM
2escapefmt's Avatar
2escapefmt
As a Ford Service Manager, and an Auto Service/Repair Business Owner, who had a close relationship with Certified Transmission- there's no more true fact than that of never changing AT fluid you are killing your transmission- death by neglect- same in all things- NO
Tesknox
May 7, 2023 05:45 PM
Whitey Ford
Oct 5, 2013 04:20 PM
VX-23 Hokie
Apr 10, 2012 11:20 AM
super d.
Jul 17, 2010 10:56 PM
trsest1
Apr 1, 2004 10:23 PM
