Best speedometer calibrator
Old Jun 10, 2013 | 10:22 PM
jmunkie13's Avatar
jmunkie13
any suggestions, running 38" tires now and things are WAY off!
Old Jun 10, 2013 | 10:25 PM
JOHN2001's Avatar
JOHN2001
I had the same problem. I also have 38s... Until I sell the truck. What I did was got ahold of a brother in my area with AE and he calibrated it for me. If you have the extra funds I would recommend you buy it yourself. I promise you it will pay for itself
Old Jun 10, 2013 | 10:30 PM
Bigtruc's Avatar
Bigtruc
X2 on what john said. I am running 38's on an 8" superlift lift kit. I just bought AE a couple weeks ago & was able to dial in my Speedo exact. Nice thing is even the odometer is right on now.
jmunkie13's Avatar
jmunkie13
what is the "AE"
Old Jun 10, 2013 | 10:48 PM
PAJARONEGRO's Avatar
PAJARONEGRO
Yeah, what is an AE? need one also.
Old Jun 10, 2013 | 10:50 PM
diehardstroker's Avatar
diehardstroker
AutoEnginuity its a software for out trucks that can be run through a laptop and read diagnostic codes and what not.
would you have to recalibrate for 285's?
http://www.riffraffdiesel.com/mm5/me...Code=F731-MISC
Old Jun 11, 2013 | 01:42 AM
jmunkie13's Avatar
jmunkie13
the AE looks pretty cool...but honestly a little more involved than I thought it would be. Now counting it out but what are your thoughts on the superlift truespeed?
Old Jun 11, 2013 | 03:25 AM
jmunkie13's Avatar
jmunkie13
Another thought...i run an edge evolution CTS module....would the AE still work since the evolution reflashes on its on?
Old Jun 11, 2013 | 05:05 AM
Tugly's Avatar
Tugly
I'm not a spokesperson for a product - I'm an advocate for members here... like you. Many here have taken our lumps and we're just passing on what we've learned:
When I was younger and had a gasser, I had a dwell meter, a timing light, and a set of tools to work on the car/truck/boat. Timing lights and dwell meters are fossils... everything is computerized now. Instead of a mechanical centrifugal spark advance, I have a bunch of sensors and a program. One sensor acts up and the program unravels... but you won't know which one if it's "too involved".
AE is a scan tool - a very inexpensive one. There are scan gauges out there, but I don't know if any of them adjust the tire size and they can cost as much as (or more than) AE. The tire size is just one simple thing (the ABS module has the speed calculations, so chips and tunes have no effect). Your truck is 10 years old and likely has some serious miles on it. I say this because gassers are typically done by 250K miles, but these rigs just need some work at that point and keep on going... and going. The first time you have a no-start, poor fuel economy, white/gray smoke, low power, or whatever... you'll log on to this or another forum and ask "why is my truck doing xyz". The reply will be questions - the first of which will be "do you have a scan tool?". From there we guide you through what readings we're looking for and explain why... the problem can even be solved quickly while you're broke down on the side of the road (assuming your scan tool is with you) . The forum has rescued many members on the side of the road in a matter of minutes this way... I think our record is 7 minutes. If your truck were to stall on the highway today, what do you suppose the first hour will be like... as opposed to the 7-15 minutes with a scan tool?
Old Jun 11, 2013 | 10:09 AM
JOHN2001's Avatar
JOHN2001
I will also add to that that I took my truck to the ford dealership to have them recalibrate the speedo... Well I had my wife take it while I was at work. When I called they said they could do it. So after an hour of her sitting there waiting a guy came out and said that he can only calibrate up to 35". I also looked all over at different things to recalibrate the speedo and most of what I found cost about the same as AE.
Old Jun 11, 2013 | 10:30 AM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Hey jmunkie13 where are you located in NC I'm in Albemarle NC and I have AE.
Old Jun 11, 2013 | 07:06 PM
jmunkie13's Avatar
jmunkie13
the AE scan tool is looking good, thanks for all of the input. Does anyone have info on the best place(price) to purchase one?
Old Jun 11, 2013 | 07:15 PM
Tugly's Avatar
Tugly
You'd better believe it. [LINK]
Yeelllooww tape {drool}
Old Jun 11, 2013 | 07:16 PM
JOHN2001's Avatar
JOHN2001
Mitch posted it once for ya but here ya go Riffraff Diesel: AutoEnginuity Total Ford Enhanced Bundle
EDIT: Tuglys quicker on the trigger
Old Jun 11, 2013 | 08:50 PM
joeyd61's Avatar
joeyd61
AE is the best way to go, but the dealer did mine (37's) for 65.00..just saying..
