4.6L Misfire issues
Old Jun 10, 2013 | 12:08 PM
arod79sae's Avatar
arod79sae
4.6L Misfire issues
Changed plugs, wires, air filter,fuel filter and ignition coils because I was running with a misfire and assumed it just needed a tune up. Still having the misfire issue at almost all the time from idle to normal driving . Checked the cam position sensor and cleaned it off . Also measured the AC voltage coming from the sensor when I passed metal passed it . Also checked fuel pressure on the test port and it read 28-30psi at idle . Put in gear and drove it and the pressure pretty much stayed right at that pressure . Also unplugged the fuel regulator at idle and it jumped up to about 40 psi and went back to 30 psi once I reconnected it.
Any ideas out there?
I am running out of ideas. I appreciate any help
Thank you
98 F150 4.6L -174k
bc18
Aug 11, 2017 09:28 AM
FordFun77
Mar 16, 2014 09:51 PM
austinlittle34
Nov 1, 2013 08:27 PM
bff
1983 - 2012 Ranger & B-Series
Jun 23, 2009 10:22 AM
460
Mar 2, 2009 07:02 PM
