How much fuel pressure do I need?
Old Mar 2, 2009 | 06:45 PM
460's Avatar
460
1997 Ranger with a 4 cylinder.
The fuel pressure at idle is 29 -30 psi.
It will jump very briefly to about 35 psi if I rev the engine.
The engine will "miss out" and idle real rough after revving it.
The catalytic converter is cracked and leaks real bad also.
Old Mar 2, 2009 | 06:51 PM
big bad 79 bronco's Avatar
big bad 79 bronco
u should have 30to45 psi check it with ken on engine off then at idle then at 2500rpm should stay in range
Old Mar 2, 2009 | 06:53 PM
big bad 79 bronco
pull one of the plugs out see what it looks like how many miles are on it u done tune up recently maybe a clogged fuel filter or air filter possibly clogged cat
Old Mar 2, 2009 | 07:00 PM
460's Avatar
460
It was at 30 before starting, at idle, and when revved.
Since it is at the bottom limit of acceptable pressure, would it be unlikely that a fuel pump is causing my problems?
I've replaced plugs, wires, coil packs, IAC, and oxygen sensor.
The engine runs nearly perfect after it warms up.
The air intake temp and coolant temp sensors both seem to be working fine, The maf has been cleaned and the voltage tested.
I haven't replaced the fuel filter, but the one on there appears to be new.
I am currently getting a P1446 code. It used to give a P0303 code, but it hasn't shown up for a few thousand miles now.
Old Mar 2, 2009 | 07:01 PM
wtroger's Avatar
wtroger
per the manual fuel pressure between (30-45 psi)
Old Mar 2, 2009 | 07:02 PM
460's Avatar
460
I've got a 2.3
