SMOKING ISSUE
Old Jun 10, 2013 | 07:41 AM
jeffcole1970's Avatar
jeffcole1970
SMOKING ISSUE
here is my situation. After a carb rebuild, on cold start i can press the pedal just barely and with a few rev of the starter it starts right up. when its warm it will start with ust a bump of the key. After driving it around the block the smoke really starts to pour it on, and it starts to smoke from under the hood. Oil has built up around the collector of the driver side exhaust manifold.
The truck sat for 10 years. I used the bg products 109 formula for preoilchange engine flush and then added some MOA after changing the oil with valvoline high mileage 10-40.
My question is does this sound like valve stem seals? The 5.0 mustang i had smoked and i found a leaky valve seal.
Old Jun 10, 2013 | 08:08 AM
69cj's Avatar
69cj
Valve seals or rings. Have you done a compression test. With out some testing everything is a guess.
Old Jun 10, 2013 | 09:01 AM
MIKES 68 F100's Avatar
MIKES 68 F100
if it's smoking under the hood then i'd say look for a bad valve cover gasket , probably dumping oil right on exhaust manifold .
Old Jun 10, 2013 | 03:33 PM
jeffcole1970
The valve cover gaskets are good. NO oil in any of the spark plug areas either. It is actually dripping out of the collector. I do need to find a compression tester.
Old Jun 15, 2013 | 07:20 AM
jeffcole1970
Compression test results..........
Only did 5, 6, 7, and 8..... I dont know what stock or good compression should be but I'm a pretty big guy and should be able to hold a tester in the hole while my gf turns the motor over. I will post the lowest numbers i got and it was 5=115, 6=110, 7=110, and 8=135 and blowing oil out of the hole. #8 kept pushing my hand out of the hole and blowing oil by the tester all over my right arm. I'm guessing this has to be valve stem seals right?
Old Jun 15, 2013 | 08:41 AM
69cj's Avatar
69cj
If it continues to blow oil and smoke after warm up the rings are probably shot.
Old Jun 15, 2013 | 05:06 PM
Argess's Avatar
Argess
Two common problems are:
1/ PCV is stuck open; and,
2/ Intake gaskets are leaking.
And by the sounds of it, your exhaust gasket needs replacing.
Of course it could be other things... troubleshooting over the net is almost always difficult.
jetfiremuck
Aerostar
Apr 13, 2017 08:26 AM
DCFord
Jun 5, 2010 11:53 AM
sleep_deprived129
Feb 20, 2009 10:33 AM
Fords&Farmalls
15
May 24, 2007 11:15 AM
barry1me
Modular V8 (4.6L, 5.4L)
Oct 4, 2006 04:01 PM
