1979 400 overheating drama solved?
Old 06-09-2013, 07:41 PM
supawah's Avatar
supawah
supawah is offline
So, got the truck from my dad, 1979 f250 4x4, always ran hot, blew the top tank, replaced hoses, replaced radiator, replaced 3 stats, 180 and 192 etc. was dragging *** on changing water pump, ran it with 1 gallon of CLR for a day, ran it full of calgon for 2 days, flushed this thing 9 times in 2 years. Nothing! Flex fan, then fan clutch. Timing, carbs, nothing. Always overheats, moving, not moving, highway, standing. So, finally in traffic, blows the top hose off and a ton of what looks like wadding comes out, like never dull pad. Great, unclogged? No! Overheats still. So, frustrated, I fill it with a bottle of Lemishine, the dish washing additive. It's used to clean dishwashers. The stuff stays in for 40 mins, turns green. I flush it out. No more overheating. Gets a little over temp 65 due to fan / shroud / weirdness. I suspect no fender wells adds to air bubble or whatever. Go figure. Fighting this for 2 years, and a bottle of Lemishine? What the hell? This is radiator number 3 and the smallest if the 3. Maybe block was lined with something? Lets see how many days it stays fixed.
Old 06-09-2013, 08:06 PM
fmc400's Avatar
fmc400
fmc400 is offline
MSEE
Are you sure you don't have a leaking head gasket? How does the oil look?
Old 06-09-2013, 08:11 PM
devino246's Avatar
devino246
devino246 is offline
I have to ask, where did you get the thermostats?
Old 06-09-2013, 08:36 PM
co425's Avatar
co425
co425 is offline
Sounds like your water jacket is clogged up, plus a corroded water pump.
Old 06-09-2013, 08:59 PM
J ballan's Avatar
J ballan
J ballan is offline
I second this. Lol. Seems silly but 335 series takes a different thermostat.
Old 06-09-2013, 09:22 PM
supawah's Avatar
supawah
supawah is offline
Thermostats
The thermostats have been from oreilly's, they have the flanged skirt on on the pellet.
Graplr
10-12-2018 11:32 PM
93F150/302
16
11-27-2007 09:09 AM
Cowboy34
04-10-2006 05:51 PM
1979F-150Man
10-03-2005 09:16 PM
dino360
10-20-2004 04:24 AM
Quick Reply: 1979 400 overheating drama solved?
