Since Ford was nice enough to keep the carpet I decided I'd add some since it was only $17 and it was high wear carpet that looks very similar to stock. It's thin backed so it bends easily.
I had only worked the pass side in when I took this pic, so still working. You have to bolt the seats in to keep it in place while you work or it'll slide and you'll end up with it in the wrong spot as you are trimming it.
Anywho, here's where I've gotten to in an hour or so.
